![]() | Home > Maintenance & Modifications > Irratic idle on cold start. |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
^ More than double of what I hoped to say in terms of both detail and clarity.
![]() More on the ECU memory issue here: http://www.defender2.net/forum/topic51730.html Solved the bowel problem, working on the consonants... |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Thank-you BW, highly detailed and very informative as usual.
![]() Agentmulder - Will take a look at your link when I have time to read later. I'd imagine the ECM memory is limited but more than enough to last over and above the vehicles lifetime. Probably 10 calibrations or 20 or similar figure. I'd imagine this is why they state that it should be done only with a VCV change and not simply because someone fancys fettle / self tune up. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17944 ![]() ![]() ![]() |
I don't think you need to worry! |
