Home > Series Land Rovers > New Wheels for my Series III
Stacey007
OK I bought it and I have a few jobs the garage are going to do before I pick it up.
I said I'm in no rush.... although I've visited recently and told them can it be ready 1st March.
In the mean time I am doing a lot of research into different things.
Chassis rust protector
Paint for body / wheels
Galvanizing
Hood sticks / tail gates / bits
I've been sourcing bits and bobs for it like rubber mats, found these wheels on ebay and they should look much better on it.
After some rear mudflaps and next purchase looking at exmoor seat belts.
Post #600964 11th Feb 2017 5:20pm
JOW240725
Thumbs Up James
Instagram @suffolk_rovers
Post #600968 11th Feb 2017 5:28pm
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Take off standard wheels with Michelin latitudes are perfect 👌
Post #600975 11th Feb 2017 6:02pm
Spectre
Pics of your Series III please!!
Post #600993 11th Feb 2017 7:31pm
Stacey007
Its nothing to write home about Shocked
but its got character, here its is, still at the garage having parts fitted,
Post #601017 11th Feb 2017 8:50pm
Spectre
Looking forward to more photos once you get the parts fitted up Thumbs Up
Post #601061 11th Feb 2017 11:12pm
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Pity to put larger 750 radials on when it look so cute on 600x16 Working towards Carry on camping!
Post #601110 12th Feb 2017 9:13am
You'll be needing a long wheelbase speedo to go with those 7.50's. Darren
Post #601139 12th Feb 2017 10:55am
Stacey007
^ How much difference will it be?
Will it under read or over read.
Loads of people do this so must be fairly common?
used a quick calculation web site , not sure of the height of each Tyre though
so came in as original at 30 mph the new ones the speedo would read 27 mph
I'm happy if its under Smile lets be honest 50 Mph would seem fast in this so if its reads 45 for example I can live with that.
Post #601212 12th Feb 2017 5:49pm
It'll read under by about 12% from memory which, apart from being illegal, is an easy way to find yourself breaking the speed limit, e.g. you think you're doing 30 when you're closer to 35.
If it was the other way around then it's legal for a speedo to over-read by up to 10%.
Yes, loads of people do it and the fix is quite easy, which is to fit a speedo from a LWB model. Unlike later models, the gearing for the speedo drive is within the speedo itself and is indicated by a small four digit number along the bottom edge of the dial. I can't remember the exact numbers off hand (I last did this mod 25 years ago Shocked ) but it's something like 14xx for a SWB and 11xx or possibly 12xx for a LWB. I'm sure that Google will be your friend to confirm the details.
One of the small niceties of doing this is that it's relatively easy to change the odometer to match the existing. The glass face comes off and then the figures can be flicked around with a pencil or cocktail stick. Whilst some will frown upon this, it's difficult to imagine getting excited about the accuracy of the mileage on an ordinary vehicle of this vintage.
I suspect the hardest part may be finding a suitable LWB speedo... Darren
Post #601230 12th Feb 2017 6:43pm
Stacey007
OK great will have a look around.
Thumbs Up
Shocked quick look on ebay found one for £220 Shocked Shocked Shocked
will continue searching Thumbs Up
Post #601233 12th Feb 2017 6:50pm
Maris Widgeon
England 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Changed the tyres on my series to 7.50s and I think that it drives better as it gears it up a little ,so the engine isn't having to rev so hard to reach "50mph" , which makes it a more relaxed drive.
As for the speedo it makes it almost spot on with the GPS. That's when the needle is readable and not fluctuating over about 20mph .
Radials also make for a nicer ride , you can always pop the 6.00 back on from time to time , nice little truck .
Nick
Post #601357 12th Feb 2017 11:13pm
PCA42
England 2008 Defender 110 Puma 2.4 DCPU Tonga Green
Those should smarten it up and make it more driveable Thumbs Up I'd probably have them powdercoated in Limestone myself for a more classic look, but since the white is so good probably not worth it.
I'd keep hold of the 6.00s and original wheels for originalitys sake.
On my 88", the speedo under reads by 5mph. Fine if you remember, I do, just one of those jobs I've just not got round to as I need to find the correct Series III type but without the trip meter from a later one. I found one but it had the wrong speedo cable connector on the back so the job got put to the backburner again Whistle Pete
2010 Discovery 4 GS TDV6
1972 Series III 88" 2.25P
Post #601660 14th Feb 2017 12:15am
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
Mine showed 25mph whilst I was sitting at 30. I put up with this for years before I picked up an old 109 to source bits from. The gearbox was a recon unit with O/D fitted so it was out of the 109 and into my 88 with it. The speedo head was also changed over and this gave me a reliable measurement of my road speed. It made very little difference to me but was one of those wee jobs that I had been meaning to get round to. Back then you could get old series motors for next to nothing as there were loads lying about that were rusted or hadn't turned a wheel in donkeys years. Still see the odd one sitting about, but mainly just a pile of rust on four wheels now a days. Old style garages usually had an old series wrecker sitting about somewhere, nostalgia - can't beat it. I'm sure I still have the old SWB rims knocking about, no idea what I'd do with them now, probably fit for scrap.
Post #601663 14th Feb 2017 12:48am
Stacey007
Will the bolts off the old wheels fit these ones?
Thanks
Post #602061 15th Feb 2017 8:03pm
