![]() | Home > Technical > Door Hinge |
Firstly, clean it up and spray if with ACF50 and see if that helps. If not, then replace the hinge. Darren
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2389 ![]() ![]() ![]() |
A drop of oil ?
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4329 ![]() ![]() ![]() |
I've been getting a rust streak from my hinges. I've been spraying with a thin aerosol grease but so far that just seems to be flushing more rust out. I'm still hopeful it will improve if I do it every time I wash the car. 2007 110 TDCi Station Wagon XS
AdamGT3 Member Since: 18 Oct 2016 Location: Beaconsfield Posts: 22 ![]() ![]() ![]() |
Thanks all.
Tried cleaning and as for Bluest just flushes more rust out and have then treated with ACF50 with the result in the photo so I guess its new hinge time. Which is best to go for? I see you can get them for £6 but are britpart ones and need painting!! Thanks |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2767 ![]() ![]() |
Genuine hinges are the only ones worth bothering with in my experience.
Has the door actually dropped? If you are having problems shutting it then I guess so but it would be worth checking as if it hasn't dropped then you may be able to get away with just adjusting the striker. The hinges will show rust for some time before they actually develop play sufficient to affect door alignment/closure. |
