Home > Maintenance & Modifications > Puma 2.2L Long Range Lights
Tumbiri
2013 Defender 110 Puma 2.2 XS CSW Orkney Grey
I'm looking at adding four 130W long range lights plus two 100W driving lights. Does anyone know what power (amps) my alternator would be rated at and whether it can take the additional load of the 6 extra lights? Locating the alternator data plate while fitted to the engine is impossible.
2013 Defender 110 SW XS.
Post #600816 10th Feb 2017 11:05pm
That's 830w inc headlights. (Assuming they are factory Halogen.) 68A current draw total @ 12.2v but not including other loads as standard.
I'd guesstimate with all lights on and everything upto and around 90A load.
Puma Alternator I think is 150A, definitly no lower than 120A. (Can someone clarify?)
Just don't run and heavy draw Amps for in car audio or similar at the same time.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #600824 10th Feb 2017 11:13pm
Tumbiri
Thanks! My 110 came fitted with the Alpine upgraded audio system with sub-woofer and I haven't done any changes to it. Does the factory system usually pull a lot of power?
Post #600842 10th Feb 2017 11:42pm
I wouldn't have thought so except for the ECU, IPAC and various other 'monitoring' electronics for engine performance etc.
Generally pretty low draw really, it's the lighting that often draws most or rear window heaters etc. Things like that.
I wouldn't be worried myself but if you'd have been drawing 100A plus it'd be something to really take into account.
I have an amp that draws nearly 50A plus, HU draw at nearly 15A and various other things too and not had any problems.
Are you running Halogen or HiD? ____\We|Will|Win/___
Post #600844 10th Feb 2017 11:47pm
grafty99
You should be fine with the factory system. Including the sub the total audio wattage in the upgrade audio kit is only about 250W
There is always the option of led headlights. A pair of those would be a 50W reduction in power usage approximately Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #600845 10th Feb 2017 11:48pm
grafty99
Also side lights and numberplate illumination add up to 30W again this can be reduced by switching to led.
Small reductions but it all adds up Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #600846 10th Feb 2017 11:50pm
^^^^ Indeed, that's what I was thinking as I don't know what the OP's LR had fitted.
Hey, I guess you may save 1p's worth of diesel economy a month through going LED. Whistle Rolling with laughter
With tail lights as standard 5w each 21w brake.
Sidelights 21w each.
Headlights 55w each
Number plate what ever that is etc all mounts up.
Interior dash lights.. ____\We|Will|Win/___
Post #600850 10th Feb 2017 11:59pm
Tumbiri
I'm running halogens. Checked the fuses for the Entertainment system and they total 40A.
Was thinking that I could power up the loads progressively while checking the battery charge. If I get a steady 14v (or thereabouts) then should be fine. Is this a good check?
Post #600851 11th Feb 2017 12:08am
leeds
What is meant by long range lights and what light output is required?
What sort of driving do you expect to do?
Stopping distance at 60mph is 73m. Allow 100% safety margin good illumination over 150 metres is good
What range of light is actually required?
Or is spread of light close to vehicle more important?
Brendan
Post #600852 11th Feb 2017 12:13am
Should be around 12.2v at rest and 14.2v alternator charging current. Give or take +/- 0.4v is acceptable I'd say.
All good. Thumbs Up ____\We|Will|Win/___
Post #600854 11th Feb 2017 12:20am
Tumbiri
Thanks fellas.
In response to the lighting requirements:
I occasionally need to drive on very dark, mountainous, not-very-good condition, rain forest roads. Hazards are landslides, falling trees etc. The more I can see well ahead the better. A good spread is also needed so that I can see the sides clearly so I mix the two types. The lights are the KC Slimlites 130W Long Range (120-121) and 100W Driving (123-124). Check out their site. http://www.kchilites.com/light-type/halogen/slim-lite.html
Post #600858 11th Feb 2017 1:06am
ericvv
Tumbiri, why go for those KC halogens? Your case surely seems to need as much light output as you can get for the used wattage. I would suggest to go for some high performance LED lights which give you much more lumen, candela, lux, or whatever else you want to call it per consumed watt. You may get a big multiple light output for less wattage by using high quality LED lights. Below is one very rugged Aussie brand which I suggest you take a look at. A combination of spot beam and flood beam lamps seems what you need from them after reading your original post.
Eric
https://www.arb.com.au/products/vehicle-li...ed-lights/
P.S. Steve, yes, all Puma Defenders since 2007 have a 150A alternator. Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #600865 11th Feb 2017 6:41am
