Home > Td5 > 10AS Alarm remote aerial location
geobloke
Ok folks this is not a life and death thing but rather caused by the addition of a faraday like cage around my Defender 110, referring to the external/internal roll cage, security grills and dog guard.
So, the 10AS alarm must have some sort of aerial that picks up the signal from the remote fob, but where is it located? Assume behind the dash.
I am considering trying to relocate it or extend it or both in a vain attempt at improving the remote functionality...
At the moment I literally have to be standing somewhere near the front doors for the doors to unlock.
Post #600149 8th Feb 2017 6:58pm
dorsetsmith
short length orange and slate Gray wire from gray plug on the 10AS
Post #600152 8th Feb 2017 7:08pm
geobloke
Superb. Many thanks Dorsetsmith. Thumbs Up
Post #600170 8th Feb 2017 7:50pm
agentmulder
Kuwait
Either replace it with longer or simply lengthen with solder joint and heat shrink then run the cable up the A-pillar behind the plastic trim.
Extends range by around 3 to 4 times original.
I can operate the alarm from inside the house now.
Thumbs Up Solved the bowel problem, working on the consonants...
Post #600180 8th Feb 2017 8:34pm
geobloke
Which must be useful when it is pishing it down as opposed to me just getting wet and accepting that is the case... Laughing
Post #600205 8th Feb 2017 9:59pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
I'm interested in this, where would I find the wire to extend it, do I need to pull my dash apart (again)?
Post #600223 8th Feb 2017 10:45pm
geobloke
By the sounds of it it is under the drivers seat. I will go look tomorrow.
Post #600225 8th Feb 2017 10:49pm
geobloke
Agent milder did you do anything to the aerial in your fob?
Post #600226 8th Feb 2017 10:50pm
agentmulder
Kuwait
Not sure it's the done thing discussing security features in a public forum, but put it this way: I found the discussing that mod on public forums Thumbs Up
But to answer questions, no didn't need to pull dash off on my puma. Depending on the size of your hands you'll need patience though. Solved the bowel problem, working on the consonants...
Post #600231 8th Feb 2017 10:59pm
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
The end of the cable on my truck ended up between the air vents on the dash. I soldered 6 ft of cable on the end and went up the A pillar and back the roof under the headlining. It works from about 30ft now. 2009 2.4TDCi XS Utility Wagon.
Post #600239 8th Feb 2017 11:20pm
mk1collector
10as is behind the drivers side speaker under the dash Ray
My build thread
Post #600240 8th Feb 2017 11:22pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Thumbs Up
I did the same recently, very worthwhile, the range has increased by 40 feet Thumbs Up
Post #600350 9th Feb 2017 1:43pm
rustandoil
I extended the aerial wire up the pillar to the roof-line, didn't make a massive difference for me Big Cry
Post #600386 9th Feb 2017 4:35pm
dorsetsmith
Post #600388 9th Feb 2017 4:39pm
agentmulder
Kuwait
Next step is to increase the fob transmission power by capacitively coupling it with the fluids in your head:
http://physics.stackexchange.com/questions...-head-body
http://www.apartmenttherapy.com/tech-myth-...-rem-83663
And no, it's not an April fools - it works.
No harm trying it by yourself one morning yeah? Thumbs Up
That combined with the aerial lengthening gives me up to 10 X more range.
Especially good if you get it first time as then the fob is 'powered up' having had no recent use. Solved the bowel problem, working on the consonants...
Post #600435 9th Feb 2017 8:27pm
