![]() | Home > In Car Electronics > Td5 max radio dimensions...? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2231 ![]() ![]() ![]() |
Any standard din will fit. I had a Kenwood KIV-700 in my 90 with no problems, the space is only limited for double dins.
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 349 ![]() ![]() ![]() |
Really? That's great! Defender 130 HCPU Td5 MY2000
If yours is a 2000 then it is has the old dash, easy enough to pull your existing radio out to check!
If you want to double check im sure the measurements for the Kenwood KIV-700 are out there! |
Since I've had the car, it hasn't had a radio. Even the fascia is not fitted, but I should have it somewhere in the pile of spare parts... Defender 130 HCPU Td5 MY2000
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
I'd just go and get one of the shallow ones with no CD slot these days, save having to beaten up all the cables to make space
