Home > Technical > Indicator relay
Jon110
England 2002 Defender 110 Td5 USW Zermatt Silver
Indicator relay
Fitted front and rear led indicators and now need to replace the relay with the adjustable one to stop them flashing like mad.
I have done a search and different answers come up so I turned engine on put on hazards and felt them all but can't feel any of them clicking.
Which one is it?
It's a 110 td5 xs 2002
Thanks
Post #599895 7th Feb 2017 6:52pm
Did you check behind dash? QRZ M8VPF
Post #599902 7th Feb 2017 7:40pm
Jon110
I didn't Embarassed
I removed the panel by the gear stick . Thought it would be one of the 6 relays there
The instructions or any of the other threads never mentioned that
Post #599905 7th Feb 2017 7:44pm
Jon110
Found the answer
So much for the instruction sheet.
Post #599911 7th Feb 2017 8:29pm
Spill...for other members?! QRZ M8VPF
Post #599912 7th Feb 2017 8:31pm
Jon110
As you said behind dash for my2002 onwards.
Will look tomorrow and see if the information I found is correct
Post #599913 7th Feb 2017 8:34pm
Thumbs Up QRZ M8VPF
Post #599918 7th Feb 2017 8:52pm
Brendlynch
Jersey 2005 Defender 110 Td5 XS CSW Cairns Blue
Out of interest did you use the wipac ones and was the relay you swapped out the 4th one along from the right?
Post #682317 28th Jan 2018 4:40pm
