![]() | Home > In Car Electronics > Show us your Anderson connection |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Seatbox floor pan but underneath? Should be out of sight, but relatively dry, but reachable.
I think there are caps / covers you can get too. I've known and seen others with one in a locking wingtop faux vent too. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
![]() I have seen the vent to really like that idea but the boxes seam expensive. |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11063 ![]() ![]() |
Iv'e got mine behind my middle seat with a cover on the end and about a metre length so can go out any of the two doors
Gmb do a lockable box that fits in the unused air vent on top of the drivers wing and I remember seeing pics on here of someone fitting the connector in the box. It was a while ago and I can't remember who did it but it looked neat and protected from the elements until needed. Ray
Capt_Steve Member Since: 10 Jan 2012 Location: Ross on Wye Posts: 39 ![]() ![]() ![]() |
Maybe this Mud one?
http://www.mudstuff.co.uk/gmb-fender-locker.html |
Yeah that's the gmb one I was on about. Someone (on here I think) fitted their Anderson connectors inside
![]() My build thread http://www.defender2.net/forum/topic17615.html |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 190 ![]() ![]() ![]() |
As I have to unbolt my 3rd party seats to access the battery I fitted one inside the battery box with access point below the front passenger seat base to provide quick access should I flatten the battery again - and also used for my solar trickle charge connection when not in use. 2006 TD5
2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 ![]() ![]() ![]() |
I have Mazda RX8 seats fitted so getting to my battery is a faff (4 bolts to undo - oh the pain).
So, as i'm always jumping people (ooooh errrr misses), I thought i'd mount my anderson connector externally. I took my positive from the starter motor and the ground to same point as my winch. I'm quite anal on ruining my lines and sticking things on willy-nilly. So, this is almost a covert install... but since upgrading to a full size intercooler, i'm going to have to move it ![]() ![]() Click image to enlarge ![]() Click image to enlarge TD5 Defender 90 Discovery 3 HSE |
^ Do you have switch between starter and connector or is it always live? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
The correct answer would be yes, there is a switch. However, that switch is still in a box waiting to be fitted. My idea was to have it simply in the engine bay or possibly hinge the spare wingtop vent and have it in there (locked) TD5 Defender 90
Discovery 3 HSE |
I would not do without a switch... It would be to easy for a scumb@g to cause a short circuit and start fireworks...
I also took the feed for my winch from the starter an so I used a switch in this (locked) wingtop box. Not cheap but excellent quality. ![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Where did you get the box VeeTee?
Thanks TD5 Defender 90 Discovery 3 HSE |
http://www.mudstuff.co.uk/gmb-fender-locker.html Cheers, Vincent
I also used the switch that does the winch as well for my Anderson connector
