![]() | Home > Technical > R380 vibrations at high revs under load |
I had a vibration at higher speeds which ended up being the crank pulley, the rubber balancer that is bonded to the pulley starts to degrade. Do you get a sort of chirp noise when switching the engine off? If so this could be your problem too. You could get a pry bar Inbetween the pulley and block while the engine is off and see if there feels to be a lot of play. Ray
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Propshaft UJs probably. Give them a good check for play.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Two things to check, thanks gentlemen. The tensioner is making a noise since the local indy changed the belt (despite me asking them to change the tensioner too). Somewhat surprised that that would cause this noise though.
As for the UJs, I hope they are good. I grease them after each off roading trip, and they have less than 5k miles on them, but I will check them too, thanks. |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Especially with a double cardon prop even the tiniest amount of play can cause a vibration
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I changed my drive belt tensioner at the weekend and it's lessened a lot of the vibration on the whole motor, still got other bits to sort though
How easy is it to change the tensioner? It looks suspiciouly like a job which I might start on then discover I am stuck without transport when I cannot put it back together again!
It's one of the easy jobs,take off the engine cover and plastic cover over the fan so you can see what you're doing. Whip the viscous fan off then get a socket on a long bar to lever back the tensioner to release the serpentine belt off the alternator and tensioner, push the slack down out of the way so the belt stays on the other pulleys so you don't forget which way round the different pulleys they go (don't ask me how I picked up that idea, there is another way the belt can go, it looks right but it's a good job the belt doesn't quite fit but it takes you a good time to realise
![]() There is a 12 sided IIRC 9/16 AF headed bolt through the tensioner body, I used a 3/8 drive socket as it was thinner to get inside the recess of the tensioner body. Undo that, remember which way the tensioner pulley on the arm was facing and replace it with the new one. There is a lug that sticks out of the tensioner body that fits in a guide on the mounting face, just get that to pop in and pop it all back together. In good old Haynes manual speak, reassembly is a reversal of disassembly. Jobs a good un ![]() Having a fan spanner, thin walled 12 sided sockets and perhaps a helping hand to hold the tensioner back when putting the belt back on as it is easier to turn the engine with a socket on the crank bolt so you can feed the belt over the pulleys is an advantage, they don't have to be skilled, I enlisted my teenage son to hold the tensioner but you could tie it up to keep it in place. |
Brilliant thank you JWL, I have all those bar the helping hand. I will get the tensioner ordered and get on and change it, cheers!
I bought a Bearmach one, exactly the same as the one(original) that came off. I do get a good deal at my local motor factors and had change to get two four pinta's of milk from a �20 note
