Home > Td5 > Skimming a Td5 head
stigomery
United Kingdom 2004 Defender 90 Td5 HT Belize Green
Skimming a Td5 head
So my head gasket failed, see thread: http://www.defender2.net/forum/topic51943.html
Having had it pressure tested the head is good (phew) but the engineering company has skimmed it prior to return to my garage... so here's my question/concern...
According to LR the Td5 head cannot be skimmed... but I've read various threads where people have done it with no issues...
Anyone on here with first hand experience, good or bad, of skimming a Td5 head?
What recourse do I have with the garage if they have the head skimmed and it all goes pear shaped?
Post #596359 26th Jan 2017 11:22am
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
I've had a few skimmed on various td5's with no issues. I am talking about very light skims however, 5 or 6 thou from memory
Any idea how much they took off? 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #596370 26th Jan 2017 12:00pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
As above. Never had an issue with a skimmed head
Post #596407 26th Jan 2017 2:10pm
Mdm
i cant comment on warranty but the firm that skims mine will not warranty the engine as it used and they cannot control how it is built etc what oil is used is it run it properly, did they reuse the single use bolts etc etc
there are 2 head gasket thicknesses i believe and you would need to know how much they took off when it was skimmed.
Post #596519 26th Jan 2017 9:07pm
psimpson7
There are actually 3 thicknesses of head gasket available and they are selected depending on piston protrusion. You should be fine to refit the same thickness head gasket that was removed. 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #596553 26th Jan 2017 10:13pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Infused to work in an engine shop, and did quite a few head skims for main dealers and heads that can't be skimmed,
Somewhere ( if they look hard enough) there will be a minimum head thickness for the actual main casting,
If the head remains within this after skimming, and the correct gasket used which is determined by piston protrusion, all was well and the main dealers were happy to go along that route,
We NEVER skimmed a head under minimum thickness for a main dealer
Hope this helps a bit ?
Post #596778 27th Jan 2017 5:59pm
stigomery
Thanks all... the garage has said they will speak to the engineering place and ask how much they took off so I await the response and next steps.
Fingers crossed
Post #596783 27th Jan 2017 6:13pm
stigomery
Confirmed they took off 5 thou, will this be okay with a standard gasket?
Post #598045 31st Jan 2017 4:23pm
stigomery
Well yesterday the engine was fired up after rebuilding the engine with the 5 thou skimmed head. Imagine my delight to hear her spring back to life, and she's running sweet as a button. Can't wait to get her back on Monday!
Post #599024 4th Feb 2017 11:17am
stigomery
And she's back on the road again, sweet as a nut (famous last words).
Very Happy
Post #600368 9th Feb 2017 2:53pm
miker
Top news! Always good to hear a TD5 doing well!
Post #600398 9th Feb 2017 5:28pm
NickMc
Skimmed loads of Td5 heads and never had any problems too.
Post #603220 20th Feb 2017 1:19am
