Home > Maintenance & Modifications > washer jet upgrade... any thoughts...
Page 2 of 4 <1234>
miker
Like the idea of the wiper mounted washers, but I am a big fan of my aero wipers... Might have to make do with the dual washer jets!
Post #595755 23rd Jan 2017 10:54pm
^^^^ I was thinking this earlier, same here.
Does the twin jet not reduce the flow and pressure. Surely double the outlet and a T or Y joint will 1/2 the jets pressure? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #595757 23rd Jan 2017 10:59pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
I done the twin washer mod and it was one of the better mods I've done, well worth it with no noticeable reduction in pressure at all Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #595768 23rd Jan 2017 11:23pm
miker
Depends whether the pressure in the single jet is limited by the pump or the nozzle.
I know if I aim mine wrong it has no problems shooting it's useless spray way over the top of the screen at 70!
Post #595779 23rd Jan 2017 11:50pm
The jets can age and corrode and cause problems I've found.
My rear one is new, the old one started to corrode on one nozzle and sprayed out the other.
Even if you tried to clear it, it'd still not give proper flow.
Replaced it and no issues again, and a better spray and flow.
At least they are relatively easy to replace and aren't very costly.
The front ones can just be a bit of a pair to get at, might consider doing the double up myself.
How did you guys do it? ____\We|Will|Win/___
Post #595788 24th Jan 2017 12:41am
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Has anyone done the double jet upgrade on a puma without removing the dash?
My washer jet assembly has broken in half some how, so I need to replace and I'm thinking of upgrading at the same time.
thanks
Darren Darren
Post #595807 24th Jan 2017 9:00am
You can replace the centre jet without disturbing the main part of the dash, but to fit a second jet you will need to (at the very least) free off the entire dash and pull it away from the bulkhead.
It is not a huge job but neither is it trivial, and it is somewhat intimidating if you're not spanner-happy.
Post #595811 24th Jan 2017 9:28am
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Here's a couple of photos as promised, of my td5. This was the easiest solution, as it didn't require taking the dash out, only the ash tray. The t-piece just fits into the pipe that the old jet was attached to and fitted through a grommet in the same hole. There's plenty of spread on the nozzles to cover the whole screen and with them fitted the the wiper arm, allow different blades to be used Thumbs Up
My 300 is a bit different to this as the t-piece is inside the dash and the pipes come out the holes on the bulkhead, where left hand drive vehicles have the wipers, which I think is much neater.
Just keep forgetting to take a picture of them when I get chance Rolling Eyes
Post #597630 30th Jan 2017 3:35pm
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
Took the dash out this morning for a look around and decided to leave the original jet in place in case I regress..
I noticed that the drivers side blanking hole for LHD wipers went straight through to the inside so I opted to route the pipes via that grommet (made 2 holes in the rubber bung) connected up and checked for leaks as t piece is inside but all looks to be OK. all connections were given a smear of silicon screen sealant.
The jets on each of the blades have 4 holes each and water goes where I want it.
Lets see how it goes.
 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #597650 30th Jan 2017 4:55pm
Romadog
I had the T piece behind the dash and the pipes went through the bulkhead via both LHD wiper bungs. That way negates the long hose to one of the nozzles. Thumbs Up
Post #597711 30th Jan 2017 7:38pm
mick
Never had an issue with my jets I run a nearly neat solution with no problems Thumbs Up
If I was going to alter anything I would look at fitting a bigger pump inside the engine bay .
Having the pipes on the outside looks wrong and is asking to be yanked off
Post #597729 30th Jan 2017 8:39pm
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
LandRoverAnorak wrote:
One of the easiest and neatest upgrades is to replace the single washer jet with two:
I'm about to do the same mod with twin nozzles! Any detailed information about how much of the dash I've got to remove on my 2010 puma 90 would be useful Thumbs Up 2010 Defender 90 HT
The longer I live..... The better I was!
Post #597890 30th Jan 2017 11:19pm
JOHNT01670
had the dash open so decided to back track and remove the wiper mounted jets/exposed pipes and install new standard bulkhead jets but I put 3 of them in and now get a nice spread of water over the screen.
Retained the standard one and added the other 2 to the existing bulkhead holes.
Pressure seems fine but I do plan, when the weather improves to add a second pump 2006 TD5
Post #605710 1st Mar 2017 11:18am
Butchers Boy
John How much work to remove enough of the dash to install the two new jets? Also what sort of splitter did you use a T or a Y piece? Any information would be useful Thumbs Up 2010 Defender 90 HT
Post #605713 1st Mar 2017 11:27am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Using blades from the first post with built-in jets on the BLADE - what happens when the blades are no longer any good? You have to buy another set at £23 or can you swap over the jets to new (cheaper) blades? TD5 Defender 90
Discovery 3 HSE
Post #605739 1st Mar 2017 1:20pm
Page 2 of 4 <1234>
