![]() | Home > Td5 > TD5 Interior Lights only activated by drivers door. |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Is it normal for just the drivers door to activate the interior lights in a TD5 Defender?
For the life of me I cannot recall noticing it before. Guess it is just one of those things I have taken for granted... Could this be just a setting in the 10AS alarm module? |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
If the other doors are rarely used then the switches can start to play up
| Nick666 Member Since: 23 Mar 2016 Location: Somerset / Dorset borders! Posts: 81
Am I right in remembering the door switches earth through the mounting screws? My driver's door one was a bit sticky but freed up easily enough.
Yes they earth through the screw
| achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161
If you have diagnostics, it's easy to check.
Look for passenger door and driver door. Just work the switches and they should show you high or low. All doors are passenger doors while driver door is separate. Failing which if you can't solve it, just connect them all to the driver door. It doesn't make a difference. The only difference is that the eka is entered through the driver door, so now you can also use any other door. The defender has migrated, leaving the owner behind. |
Thanks guys. Ok. Well I replaced all the switches a year ago, so perhaps it is a bad connection through the retaining screw. Kinda strange that they have all gone faulty at the same time.
Hi Achuakh I do have a nanocom, but I am still getting to grips with it. I assume that the this is in the 10as section. Will go and have a look. Another job to add to the list |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
sent you PM re 10AS
| bogwert Member Since: 03 Sep 2016 Location: Dundee Posts: 194
Hi Bogwert, same here
I'm sure there must be a better switch solution than the factory. It's a pretty unreliable design!
