![]() | Home > Maintenance & Modifications > Hazard Light Switch |
| 2 GOS Member Since: 03 Aug 2014 Location: Hertfordshire Posts: 66
Hi,
I am not sure if the bulb has gone or if it just does not have one. Can anyone tell me if the hazard light switch on a Puma should light up? TIA |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
No expect it should yes. Mine has gone as well. Bulb you need is a T3 bulb. You can get traditional or led like these,
[url]https://www.ebay.co.uk/itm/152204726549 [/url] I will be getting these shortly. Looks odd at night without the switch illuminated... |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Maplins you can use these below
http://www.maplin.co.uk/p/12v-096w-wire-ended-filament-type-wq13p |
| Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514
This is the bulb for the Hazard Switch
Part Number : STC1205 Click image to enlarge Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Cheers, bulb ordered.
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
thanks guys....can you get the switch out without removing the dash?
| All times are GMT |
