![]() | Home > In Car Electronics > Cruise control and warrranty |
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
OK... Had the same issues whilst my 110 was under warranty... Basically if you cut or modify the wiring it is no longer covered under the manufacturer's warranty.. If it causes any issues they aren't covered either...
I made y-piece sub looms to connect my cruise kit... So no cutting of the std loom was required... My cruise has been fitted for around 3 years now... With no issues... Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
| dantastic Member Since: 04 May 2010 Location: London Posts: 367
Thanks for that. Yea, along the lines of what I thought.
It looks like Mobile Center's unit is a plug-in unit these days. I'm not sure, It's says Plug and play throttle T harness. Looking at the pics there doesn't seem to be any lose ends either but I haven't found any fitting instructions. Might have to phone them and ask. http://www.mobilecentre.co.uk/index.php?ma...cts_id=643 |
Unless they've changed the kit... Only the Throttle Pedal and the control stalk are truly plug and play... you will either need to cut or splice the follow..
Brake Switch Clutch Switch Speed pickup... you will also need to add a power feed off the ignition switch or smiliar Hope that help Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
