Home > Td5 > TD5 Injector Balance - Nanocom - Noisy Injectors
geobloke
Hi All. Just getting to grips with being able to monitor my TD5s systems. Should of got a Nanocom long before now, already massively useful.
So, wondering if anyone can advise on these injector readings;
These were recorded whilst at idle and still. These injectors have all covered 170k miles and have had a number of new o-rings, sealing washers and injector looms as a matter of routine servicing.
Recently the injectors have begun to sound quite noisy, really quite clackety, definitely not as sweet as before. I am fairly sure that the injector balancing data should if all is well be throwing out values of no more than +3/-3. Is that right?
Do these injector readings look ok? It'd be great to see what other poeples TD5 readings look like if anyone feels like plugging theirs in and posting the graphs.
Also, are the spikes in the idle error graph related to the injector readings and is it something to be concerned about?
Post #597058 28th Jan 2017 8:04pm
Cactus79
Haven't played around enough with the nanocom to work out how to do that with the graphs but can put it on tomorrow at some point.
Post #597060 28th Jan 2017 8:10pm
geobloke
Hi Cactus. That'd be great, many thanks in advance. Be warned: once you start down this Nanocom route it does have the tendancy to become quite addicitve... Whistle Whistle
Post #597064 28th Jan 2017 8:14pm
roel
Yes and you find more potential problems then there really are. Twisted Evil
I just have the old style Nanocom with a small problem, it doesn't want to communicate with my Laptop. But on the injectors being between -3 and 3 I think that is ok. I never looked into that indetail so I don't know if that fluctuation that you see is common.
The spikes in the rpm. I don't know what caused that. Roel
2003 90 Td5 (2009-now)
Post #597218 29th Jan 2017 11:37am
lightning
Have you tried extra bulkhead sound proofing?
If you fit sound proofing you won't hear the injector noise and then there's no need to worry about it any more.
Post #597638 30th Jan 2017 4:06pm
geobloke
HA too true Lightning... The problem however is that I did fit extra sound proofing and it seems the injectors are adapting to my new defences...
First step is to whip off the rocker cover and check all the clearances are A-OK. Then I guess see where we go from there. I did get a quote for a set of 5 recond' units just for interest sake - £1500 exchange for your old units... Shocked Shocked Funny enough cotton wool in the ears seems to work pretty well too...
Post #597639 30th Jan 2017 4:14pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Cheaper to buy them from Land Rover Shocked
Post #597665 30th Jan 2017 5:36pm
geobloke
No kidding. Shocked
Anyone know of any injector specialists that do not charge two kidneys and your first born??
Post #597668 30th Jan 2017 5:55pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Having recently been through injector woes......
Buy Landrover ones!
Chris
Post #597734 30th Jan 2017 8:44pm
lightning
Can yours not be reconditioned if they are tired?
Post #597782 30th Jan 2017 9:40pm
