Home > Td5 > Propshaft's 2005 TD5 Alignment
randallised
Ireland 2005 Defender 110 Td5 XS CSW Java Black
Howdy , just replaced the clutch, flywheel etc and forgot to mark the shafts. The front prop seems to be off set (30 Degrees) at the UJ's so the two ends do not line up when on the floor ? Is this the way the front is supposed to be ? Would the two ends not be fighting each other ? The rear looks right.
Any help much appreciated
Post #596864 27th Jan 2017 10:06pm
lightning
I just looked at both of mine and they are the same, the front/rear flanges do not line up.
Post #596879 27th Jan 2017 10:45pm
Retroanaconda
Front prop should be slightly out of phase. Rear prop should be in phase.
Due to different planar alignment of front diff and transfer case flanges.
Post #596885 27th Jan 2017 11:04pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
What he said! ^^^^ 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #596930 28th Jan 2017 11:14am
randallised
Thanks all very much, appreciated.
Post #597146 28th Jan 2017 11:51pm
