Home > In Car Electronics > Discreet reverse camera screen
Page 3 of 3 <123
Stiff1
Startech have a demo car with the screen in a cradle in the top "dip" in the centre of the dash, could fabricate one of those for your chosen screen, looks very factory.
Post #596679 27th Jan 2017 11:50am
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
As far as I was aware you need 2 mirrors for MOT one of which has to be drivers side wing mirror. The screen is completely out of the swept area of the screen. Has been on there since new so had 3 MOTs like it and passed every one. 2009 2.4TDCi XS Utility Wagon.
Post #596693 27th Jan 2017 12:22pm
blackwolf wrote:
You may want to bear in mind that on a vehicle this recent, you must have an internal RVM if it gives you a view to the rear. In order to be able legally to get rid of it, you would need a 100% opaque tint on the rear window (which actually may also be illegal) or a solid bulkead between the driver and the rear of the vehicle.
I'd never come across this before so had to look it up. I didn't realise that the requirement had changed beyond the 'two mirror' rule, but it did for new vehicles on 26th Jan 2010. The requirement now is two external mirrors plus 1 internal 'unless the internal mirror cannot provide an adequate view to the rear'. Can't find an easy reference for 'adequate' though.
https://www.gov.uk/government/uploads/syst...irrors.pdf Darren
Post #596697 27th Jan 2017 12:36pm
ChrisWoods
So mine being late 2009 is fine then? And considering I have a tyre and dog guard in the way, I can't see out the back anyway. 2009 2.4TDCi XS Utility Wagon.
Post #596700 27th Jan 2017 12:43pm
Based on the date, yes.
If it were a later vehicle, I don't know whether the tyre and dog guard would mean it doesn't pass the 'adequate' test. Darren
Post #596702 27th Jan 2017 12:49pm
ChrisWoods
If a golf sized car pulls up behind me I can't see it at all in the rear view so I think that is inadequate. 2009 2.4TDCi XS Utility Wagon.
Post #596707 27th Jan 2017 1:07pm
It's a silly rule (thank you EU) and I have never heard of anyone falling foul of it, but it is best to know.
I have a solid flap on the IW canopy on my DC, so all I could see in the interior RVM was the reflection of headlights coming towards me reflected in the rear window of the cab! I removed the RVM and replaced with a MUD RAM mount ball, which isn't terribly useful but looks better than an empty mirror mount.
Post #596714 27th Jan 2017 1:46pm
mse
This is mine
Ill take one if i remember when its on. The wire is now hidden this was before i finished it
 Mike
Post #596758 27th Jan 2017 4:47pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Fitted one of these a few weeks ago triggered by the reverse gear switch, appears to work OK.
It's a Auto-Vox with a 4.3" LCD screen from amazon around £70.
Fitted with a Discovery2 mirror bracket and a custom made fixing plate to the roof.
Only problem now I need to cut down the sun visors as they hit the mirror !
Post #596776 27th Jan 2017 5:45pm
mse
I looked at that type - they are good but move the mirror high up and were a bit more expensive. How are you finding it? Mike
Post #596779 27th Jan 2017 6:04pm
Def90
Hi Mike
I'm very happy with the mirror up higher, gives better visibility, along with it's wider than the standard one and work well as a rear view mirror.
Post #596794 27th Jan 2017 6:34pm
mse
Looks smart - mine is wider the standard - except its a little narrower than yours, if its the same specs i found
I didnt really want to drill anything which is why i liked mine - but it puts it in line with the original, which means the visors still work 90% the same as they did
Did you power yours from the dash fuse box? Mike
Post #596813 27th Jan 2017 7:33pm
Def90
It's powered from a new fused circuit via a relay that's triggered by the reverse gear switch.
Using a independent power supply via a relay supposedly reduces any distortion of the image on the screen by interference from the reverse gear circuit.
Post #596823 27th Jan 2017 7:49pm
mse
Ahh mine has its own wiring its only the camera that has a reverse trigger - would have made wiring easier . i need to turn the guidelines off it though - one of those jobs i never remember to do until reversing!!
 Mike
Post #596829 27th Jan 2017 8:10pm
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Came across this one on amazon. Has the buttons on the front, however size may make it a little large for mounting in the OP location.
https://www.amazon.co.uk/dp/B01HV3P224/ref...&psc=1 Keith
Post #601199 12th Feb 2017 5:00pm
Page 3 of 3 <123
