Home > In Car Electronics > Discreet reverse camera screen
Page 1 of 3 123>
dantastic
I remember seeing in a post some time ago a small reverse camera screen mounted on the flat heater panel, just in front of the gear stick. To the left of Center Diff Lock instructions sticker.
I have been searching the forum but I just can't find the post. I'm looking for a small screen to put in that exact spot. Discreet and out of the way.
All screens I have seen on the bay all have menu buttons on the back so you couldn't mount them on a flat surface.
Post #595541 23rd Jan 2017 11:33am
L110CDL
Do you mean this one Whistle
 Clayton.
Keeper.
Post #595763 23rd Jan 2017 11:14pm
dantastic
Not that one unfortunately. It was mounted flat onto the heater blower panel on a puma.
But thanks for playing Very Happy
Post #595824 24th Jan 2017 10:24am
Stacey007
Hello
Why do you need to get at the menu?
I've tried two types now, a flip up one and flat one with as you say the menu buttons on the rear. I've never used them?
Once in place it works no need unless you have two cameras and want to go to AV1 or AV2?
Post #595829 24th Jan 2017 10:33am
dantastic
I've no idea if I need to get at the menu buttons or not. But if I glue the monitor in place I won't ever be able to get at them. Not even sure what they do tbh. I'm after just a very simple display, single input for reverse camera only. Just want it tucked out of the way.
Post #595837 24th Jan 2017 11:01am
Stacey007
The one I have does very little on the menus
Swap between 2 inputs.
brightness, contrast, 16:9 or 4:3
I have never changed them and doubt you would ever so would think any would do?
Post #595845 24th Jan 2017 11:21am
Stiff1
You could go down the rear view mirror integrated route or fit it to the sun visor?
Otherwise, go all in and go double din.
Post #596355 26th Jan 2017 11:08am
Ifor Williams do a stand alone one, or you could go the routes suggested. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #596372 26th Jan 2017 12:04pm
dantastic
No interest in a double din unit. Waste of money.
I've tried the mirror with integrated screen. Was sent back after a few days. The mirror only works properly in certain light conditions.
I'm going to just get a basic one like suggested earlier and hope I won't need to use the menu buttons.
Post #596379 26th Jan 2017 12:17pm
It is a problem in the Puma due to the lack of anywhere readily available for the screen.
I don't want a rear view mirror solution, because I don't have an interior RVM!
I don't want to go double din (way too expensive and too much hassle just for a screen).
Has anyone had any experiences, good or bad, with single din flip screen units? I notice that several of these have camera inputs and thought that that might be an option.
Post #596394 26th Jan 2017 1:21pm
As you haven't got a rear view mirror, is that not the ideal place to mount a screen instead? Darren
Post #596405 26th Jan 2017 2:09pm
grafty99
Yes bad, I had one and sent it back because it covered way to many switches and with the loom on the back it was very tight to fit all the wiring in (Td5 admittedly)
Couldn't reach hazard rear and front heated screen and rear windscreen wiper and wash in mine Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #596409 26th Jan 2017 2:21pm
That is exactly what is putting me off trying one - I couldn't reach the switch for the hazards, more importantly I couldn't reach the switches for the heated front screen and battery of all-round scene-lighting.
I could mount a sceen above the centre panel of the dash but that would obscure the clock.
Guess I'll just continue to live without a reversing camera!
Post #596413 26th Jan 2017 2:41pm
An interesting idea, though it would have to be a fairly teeny screen. I will investigate.
Post #596415 26th Jan 2017 2:43pm
Just adjust the screen out so there is room behind.
Have it set manually so you can open and close it when you like.
Not used mine in ages, it's playing up.
1 DIN or 2 it's all gone way way to expensive to be worth it now & what ever you buy will be out of date in a couple of years. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #596417 26th Jan 2017 2:44pm
Page 1 of 3 123>
