![]() | Home > Puma (Tdci) > Muddy Flaps |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
http://www.defender2.net/forum/topic3196.h...amp+bezels If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Cheers Mal
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
on our third set of headlight rims 2.4 90 XS
| jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
Aluminium ones are avaailable from Croytec at (ahem) £125 a pair
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363
Thanks JST.. Cow and sheep waste will rot a Defender to dust ten times quicker than salty roads. I once had a Shogun courtesy car and it was previously loaned to a sheep farmer and there was ZERO paint left on the underside and it was the last vehicle Western Motor Group would ever loan to a farmer as the Shogun needed grit blasted before it was 3 months old. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
best not to wash them with that then,I'll stick to bat pixx 1968 1/32 scale Britains 109 Pick up. |
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513
On my 3rd set of headlight surrounds. I'll get me some of those chrome ones ASAP.
Your mudflap brackets shouldn't have rusted - mines 3.5 years old and they're fine. Try pointing it out to the LR chap next time you're in (they're an accessory and should be covered under warranty). If not, just paint them yourself - at least you know it'll be done properly. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
You learn something new every day
| Bruno Member Since: 29 Oct 2010 Location: Aberdeenshire Posts: 16
Collected my 110 yesterday after getting the rear mudflaps replaced FOC - Bought the car September 2010 and have covered only 3700 miles!
Stratstone Perth not a problem! |
| marklockett2103 Member Since: 08 Feb 2011 Location: West Sussex Posts: 32 |
My back ones are being replaced today, only had it since 15 december, also in for pretty major leak in the back, air con keeps blowing fuses, radio is useless, and the central locking on the back door is intermitent. other than that i love it
| jav-uk Member Since: 29 Mar 2010 Location: Shropshire Posts: 112
My 110 UW is in the stealers for its first service on Monday. Just clicked over 12000 miles.
Engine and drive train have been faultless....... but........ Rust on the Mud flaps seems to be a common issue. The paint has blown on mine and rust is showing. I have requested they are replaced under warranty. I also have a rear de-mist which is only half working and the key locks have been hammered by the cold weather/road salt so they are corroding earlier than expected. I am concerned that some forum users are not getting mud flaps replaced under warranty. I will post an update after the service. Paul Pondering a New 90 Commercial 2020 Evoque * 2014 110 SW JE Stage 2. *2010 110 Utility. JE Stage 2. *2007 110 SW *2003 90 JE Stage 2. *2000 90 SW If its not leaking it ain't full. |
the dealer will change them under warranty and again if they go again,
the hrw is a known fault due to a batch of duff windows 1968 1/32 scale Britains 109 Pick up. |
| Boulty Member Since: 24 Nov 2010 Location: chicheley Posts: 22
my mud flaps went rusty in the first week of having it! only had it since the 18th december!!!! makes the truck look a right f@cking mess. puma 110 utility
td5 90 |
Happy Days
Back from first service and very pleased. Mud flaps - replaced Locks - replaced all round and new matched set of keys. Rear glass - replaced - plus new breather fitted to gas tank. No fuss or hassle from service desk, warranty covered everything and the vehicle was spotless when I picked it up. Muddy again now though. Shukers Shrewsbury Pondering a New 90 Commercial 2020 Evoque * 2014 110 SW JE Stage 2. *2010 110 Utility. JE Stage 2. *2007 110 SW *2003 90 JE Stage 2. *2000 90 SW If its not leaking it ain't full. |
