Home > Td5 > Thermostat
Welkman
Thermostat
Hi All,
Driving into work this morning I got caught in traffic and my engine temp dropped to cold. It was about -2 out and I was stationary for twenty minutes. My thermostat is only 12 months old and a genuine item and the coolant level is fine. Any advice?
Thanks
James
Post #595577 23rd Jan 2017 1:41pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I think it's something they all do. the engine doesn't give out enough heat so the heater just cools it down.
Every rev it a bit when it cools or fit a rad muff. I'm running around with a radiator muff/cover at the minute 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #595585 23rd Jan 2017 2:12pm
grafty99
To combat this I removed my viscous fan. Have had it removed for nearly 2 years now and not the slightest hint of overheating. If you are worried about it you could just remove it for the winter Thumbs Up
Even with a rad muff if you still have the fan it still draws cold air in Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #595592 23rd Jan 2017 2:35pm
grafty99
Also check if you have the fuel cooler coolant restrictor installed Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595593 23rd Jan 2017 2:36pm
roel
I had an off-road event last weekend and had the same. When idling for a while the gauge showed cold but I still got warm air from the heater. Looking at my nanocom the Coolant temp was still somewhere in the 60 C area, so it's not that it gets really cold. Roel
2003 90 Td5 (2009-now)
Post #596089 25th Jan 2017 8:01am
Welkman
It is strange though as I thought that the thermostat bypasses The radiator when cold in order to keep things at the corrrect working temperature. Surely you should not need to remove the fan and cover the rad of there is nothing flowing through it?
Post #596122 25th Jan 2017 12:09pm
grafty99
The fan will still be blowing cold air across the engine block and also if the ambient temperature is low it will help cool the engine internally as it is drawn in. Although the effects of these are small - on an engine that already produces little heat it will have a noticeable effect! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #596158 25th Jan 2017 2:22pm
roel
I think most off the heat is going to your heater to try to warm the interior up. Roel
Post #596159 25th Jan 2017 2:27pm
grafty99
Yes hadn't thought of that - definitely going to take some heat out Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #596164 25th Jan 2017 2:44pm
geobloke
It would be worth checking your viscous fan is in good order. If it seizes in the locked position it will obviously suck more cold air through your rad.
The other thing I have seen is someone fitting an auxilary pump in the coolant system to assist the standard pump whilst sitting in traffic. The idea was that the engine was still hot enough but the coolant flowing through the heater matrix wasn't moving fast enough to heat the incoming air. I cannot however remember if the system worked, but it is a good solution.
Heated seats make life a little more comfortable, easy mod too.
After that it is time to think about an auxilary diesel heater.
Post #596188 25th Jan 2017 4:42pm
Welkman
yep makes sense it was -4 ! I think I will fit a rad muff and my heated seat kit when I get a moment.
Post #596258 25th Jan 2017 10:10pm
miker
I need to fit a rad muff to mine, just doesn't get that hot in the winter!
Not going to remove the fan as I do use it for a fair bit of heavy towing.
Post #596263 25th Jan 2017 10:17pm
I can thoroughly recommend this one, the Combo Cover, made by a small company called GlobeRoamer:
This is the second one I've had and is a refinement on the original design. It can be opened to any degree by way of two zips.
Also available in canvas. Darren
Post #596271 25th Jan 2017 10:25pm
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Same problem - so viscous fan removed and twin electric fans fitted to an XEng X-Fan Thermostatic Fan Switch; Rad Muff fitted and also changed the cap on the header tank as pressure wasn't being held as much as it should and replaced the thermostat. Adventure isn't paved!
Post #596830 27th Jan 2017 8:11pm
