Home > Technical > Tdci Doors onto a Tdi
chrispy
Wales 1987 Defender 90 300 Tdi CSW Keswick Green
I'm going to replace the doors on my wifes Defender and wondered if the Tdci doors are the exact same size and would fit onto the Tdi body? The reason I ask is I plan on upgrading it with central locking and electric windows and can get hold of two doors off a Tdci with the glass, electric and locking mechanisms complete a lot cheaper than I can buy the parts and it would save some fitting headaches too.
Thanks in advance.
Post #595608 23rd Jan 2017 3:29pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
I'm sure the defender size door has not changed since series 3? So I'm sure it will be fine. Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #595613 23rd Jan 2017 3:49pm
grafty99
Yes, direct swap Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #595618 23rd Jan 2017 4:19pm
Mo Murphy
Since series 2 😉 The Land Rover 90 - Many are called, few are chosen.
50 Shades of Pennine Grey
Post #595636 23rd Jan 2017 6:01pm
Mash
Cheers Mo, knew it was one of them Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #595639 23rd Jan 2017 6:10pm
chrispy
Thank you. What else would be needed to get the electric windows to work? My wifes 90 has a Td5 wiring loom in it and i'd like to make this as effortless (and inexpensive) as I can. I've seen kits online to add electric motors to the windows but if I could utilise the ones on the Tdci doors i'm looking at all the better.
Thanks for all your help chaps, this place is amazing for knowledge, help and also encouragement. Others just say not to bother but here it seems to be f*** yeah...go for it!
Post #595648 23rd Jan 2017 6:34pm
Romadog
You can do it.
I did the same.
Bought a Td5 bulkhead loom that supported electric windows and central locking.
I then extracted the relevant wiring and then grafted it into the existing loom, utilising the same routes and plugs.
The central locking was easy as the wires are pink or orange and they just got soldered into existing ones from the alarm ecu. The alarm ecu needs changing if you don't have central locking already. They can be modified, but if you search for the right one they do come up on ebay.
So by doing the wiring pretty much as LR did it - if an issue occurs then any help on usual remedies from people on here will be of use rather than a 'Well it could be any one of many things....' !!!
Happy to answer any further questions on this Thumbs Up
Post #595656 23rd Jan 2017 6:55pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
You don't need a special loom for electric windows, Power from battery to fuse, then to carling switch per window then to electric window motors.
You Do Not need a relay dead easy.
Central locking is different kettle of fish Alarm fitter wired mine
Post #595700 23rd Jan 2017 9:00pm
chrispy
Thanks guys, much appreciated Thumbs Up
Post #595728 23rd Jan 2017 10:05pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
On another note, I would also want to be certain that the doors that were for sale had a genuine reason for being on sale and weren't removed from one of the numerous stolen Defenders that are mentioned here on a weekly basis. 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #595741 23rd Jan 2017 10:21pm
Gurmot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I would also be checking they weren't stolen. A pox on anyone who sells stolen defender parts Exclamation
Post #595749 23rd Jan 2017 10:33pm
chrispy
It was rear ended and an insurance write off. I'd never buy anything Land Rover without checking it's genuine and not stolen first.
Post #595798 24th Jan 2017 7:04am
