Home > Maintenance & Modifications > Rusty XS Side Step
AdamGT3
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Corris Grey
Rusty XS Side Step
Hi
I have noticed some rust and flaking paint on my XS Side Step.
What is the best solution to treat the rust and re-paint. Its only on the near side at present.
Thanks
Adam
Post #594740 20th Jan 2017 3:38pm
Balvaig
Halfords satin black is a pretty good match to the original black. Don't forget to treat the insides with rustproofer such as Dinitrol. There are two drain holes which can be used to access the inside. Smooth Hammerite is also quite good.
Post #594745 20th Jan 2017 4:14pm
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
There is also a POR15 starter kit on Ebay which is pretty good
Post #594750 20th Jan 2017 4:45pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Take it off the car. Use a flap disc on an angle grinder to remove loose paint and power through the rust until its gone. Then take it to be shot blasted and powdercoated.
That's what I did and it looks factory fresh. 1953 80"
1987 mini city e
2011 90"
Post #595150 21st Jan 2017 11:59pm
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
If your steps have been on from new then once you've removed them give them a good looking over. They rot from the inside out pretty good.
Post #595223 22nd Jan 2017 10:37am
Bluest
I've just done mine, was a real rush job but they've come up quite well. Getting the old powder coat off was easiest with a stiff wire wheel in a drill. For paint, I would recommend Buzzweld, by far the best aerosols I've used. Much better coverage and less prone to running than Halfords products.
Drill out the rivets and remove the tread plate and rubber, that way you can go at the steel without having to work around it. The rivets are a large size so you'll need a lazy tongue riveter to reinstall. 2007 110 TDCi Station Wagon XS
Post #595226 22nd Jan 2017 10:41am
Bluest
And don't bother trying to salvage the plastic end caps. You can buy new ones for a quid on eBay. 2007 110 TDCi Station Wagon XS
Post #595228 22nd Jan 2017 10:43am
