Home > Td5 > Light bar installed in my TD5
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I’ve just fitted a light bar to my Defender 90. I didn’t want to roof mount it and played with the idea of fixing it to the bumper but didn’t want to spoil the line of the truck. HuffHuff has mounted his within his grille so I cannot take any credit for having the idea but thought it might be interesting to document what I did, for those interested.
As I wanted to mount it in the front grill there is a width restriction. 68cm’s was as much as I could get in so the biggest one under that, that I could find was 21”.
Having a look around on the net and weighing up price against quality I choose this one:
http://www.flatdoguk.com/21%22%2Dfd%2Dpred...bar%7E1411
I actually bought it through “Paddocks” as they did a price match.
As it needed to be as recessed as possible so it wouldn’t stick out too much from the grill I needed to cut some on the heat-sink fins from the bar. I’m sure I have invalidated any warrantee I had!
Once this was trimmed I offered it up to the position I wanted which is as high as I can go in the grille. From this location I took rough measurements of the brackets I needed to make to support the bar. I wanted to use holes already there and found a pair of bolts either side holding the radiator/front panel in place. My truck has enough holes without making too many more!
These are what I came up with:
I had previously trimmed a new grille I bought for the project as you can see. Once it was cut it all went a bit limp so I have reinforced it with brass bars (3mm) and bonded them to the plastic. The bonding isn’t too neat but only I will know as you won’t see it when fitted!
Two of the larger brackets fitted
This is the finished install. The bar is slightly proud of the grille but I’m happy with it.
A few weeks earlier I fitted an upgrade loom for my headlights so have wired into that to fire up the bar when on full beam.
It’s very bright!
Thanks again to HuffHuff for the idea Thumbs Up Thumbs Up Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #594782 20th Jan 2017 7:17pm
grafty99
Looks neat Thumbs Up I've got mine behind the lower grille. As you mention it doesn't upset the lines of the defender Cool
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #594785 20th Jan 2017 7:23pm
Nick666
United Kingdom 1986 Defender 90 2.5 n/a Diesel SW Yellow
Those look really very neat, nice work! Smile
Post #595146 21st Jan 2017 11:54pm
grafty99
Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595162 22nd Jan 2017 1:08am
mk1collector
Grafty, Any pics of how you mounted yours? Ray
My build thread
Post #595167 22nd Jan 2017 1:41am
grafty99
I don't but basically it's bolted through the grille.... 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595169 22nd Jan 2017 1:52am
grafty99
Hang on I'll pop out and take a picture 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595170 22nd Jan 2017 1:53am
grafty99
1990 Vogue SE
Post #595171 22nd Jan 2017 1:55am
mk1collector
I like that Thumbs Up might have to nic that idea but with two seperate lights (one for each side of the grille) does the grille have any negative effects on the light output? And do you have any pics of the light output from inside the cab ? Ray
My build thread
Post #595178 22nd Jan 2017 2:36am
grafty99
I haven't got any pictures from in the cab but will try and get some tomorrow night.
I have also mounted 2 lights individually on my 110. Slightly different approach though as it had aircon.
I'm sure the grille does reduce light output but not enough to worry about Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595179 22nd Jan 2017 2:49am
grafty99
1990 Vogue SE
Post #595180 22nd Jan 2017 2:53am
grafty99
1990 Vogue SE
Post #595181 22nd Jan 2017 2:55am
As much as I love and use my RI lights, I don't want them spoiling the 90, through the grille would be perfect.
But even there I can't do it Big Cry there's only a hole for the starting handle Laughing
Post #595203 22nd Jan 2017 9:12am
grafty99
Is there enough room between the radiator and the grille to mount something? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595209 22nd Jan 2017 9:57am
mk1collector
Thanks Grafty Thumbs Up Greeni couldn't you change the grille surround for a later one? It would get rid of the unused bonnet lock hole at the same time. Ray
My build thread
Post #595289 22nd Jan 2017 2:26pm
