Home > Maintenance & Modifications > Thinking about an exhaust (again)
Cake
Thinking about a cat back system in stainless to remove the oversized rusty standard one.
I'm not looking for noise (don't see why you would on a diesel straight 4), just something cleaner, shinier and prettier.
I'm personally not a fan of the silencer box behind the wheel, the huge resonator that many have issues with off road and no tail pipe welded on the end!
Has anyone any got anything to add that I should be looking for or any recommendations?
Also from previous research I believe the silencer and resonator removal doesn't add too much noise?
I'd rather remove the silencer and have a smaller resonator.
Post #593484 16th Jan 2017 11:48am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
Try the guys at Pipecraft in Basildon. They will build you whatever you want in mild steel or stainless. They did a great job on my old Discovery.
Pipecraft
Unit 23
Orion Court
Cranes Farm Road
Basildon
Essex
SS14 3DB
T: 01268 285 535 Cheers Don.
Post #593516 16th Jan 2017 3:07pm
Cake
Thanks - heard these popup a little bit so may drop by and see what they can do Smile
Post #594075 18th Jan 2017 1:17pm
DAZ110
What about either Alive Tuning or Griffin Performance ?
Post #594077 18th Jan 2017 1:35pm
Cake
I've looked at both but I cant see any pictures for the Griffin one to see what you actually get, though they are well regarded.
The Alive one looks just right but cant really find any reviews on it and price top money too (for me).
Post #594080 18th Jan 2017 1:45pm
DAZ110
The Griffin exhausts I saw at Peterborough Landy show looked very well made. Thumbs Up
Might be some info here you might want to read including the links?:
http://www.defender2.net/forum/topic13619.html?highlight=griffin
Post #594091 18th Jan 2017 2:31pm
josefk
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
My experience may not be typical but I had a "made to measure" SS exhaust on mine and I was (and am) pretty disappointed with the execution of the exit - it isn't properly curved and swept out of the corner (I have a 90) and even at the second attempt the vendor managed to disappoint. This wasn't something I imagined would be a problem and wasn't something I screwed down in my specification/description before having the job done. Afterwards is too late of course.
With the non made to measure - i.e. Griffin (look good in the flesh), Alive, and the one TMD sell (but I've forgotten the brand) you can at least check this kind of thing before committing. FWIW I wish I had gone for a Griffin or TMD one...
Per noise and other non-cosmetic considerations - straight through and out after the DPF/CAT on my TDCI hasn't increased noise at all (there is a v.small "tizz" on revs for about one minute after first starting and I presume this is a resonance due to temperature/dimensions of something or other) and has really physically tidied up both back towards and over the rear axle (losing the big muffler was my main motivation) and has made the rear arch more open and moderately easier to jet wash down (it wasn't exactly tricky before...Smile.
Post #594114 18th Jan 2017 3:50pm
Chopperone
I am having a Griffin fitted in a couple of weeks time to my 2.4.
Fortunately I live near to Griffin & James is going to have a play around at giving it a slightly more aggressive sound without being intrusive.
Watch this space
Guy
Post #594858 20th Jan 2017 10:46pm
williamthedog
The turbo will dissipate most exhaust noise anyway
Post #594866 20th Jan 2017 10:56pm
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
I have a full griffen on my 90 td5 great exhaust well made nice people to deal with Thumbs Up
Post #594872 20th Jan 2017 11:18pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I had a local specialist build a stainless side exit tailpipe about a year or so back. Then I replaced the middle box with straight through pipe. The exhaust isnīt noisier at the tailpipe, but removing the middle box did result in a little more resonance under the cabin, at speed, but not so much to be a bother.
The tailpipe gets the system up and out of the way. It took a couple of goes to get it positioned right so the it didnīt touch the edge of the aluminium bezel under extreme temperatures (heavy trailer in summer), when the system expands. The pipe moved about 6-8mm rearwards, and needed a stiffer rear mounting to reduce this. Works perfectly, and in my view, it suits the Defender really well.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #594900 21st Jan 2017 8:33am
Froglaise
Nice looking piece/mod that, but I thought custom exhausts were illegal in Germany?
Post #594904 21st Jan 2017 9:00am
Morepower
New Zealand
I have Bowler Cat back systems on both the 110 and 90... Stunning pieces of kit but not cheap... No real noise increase (maybe slightly)... However, there is a noticeable improvement in low end turbo spool up...
Regards
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #594910 21st Jan 2017 9:59am
Wild Card 90
Not at all. You need to get the TÜV to look at it, and they are very touchy about the db's . Not an issue here. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #594918 21st Jan 2017 10:19am
5 POT
United Kingdom 2005 Defender 110 Td5 SW Java Black
Twisted full system for the 2.4 sounds great - I got mine with the extra silencer in the mid pipe, so it has no drone in the cabin at all but makes a 4 cylinder transit engine sound quite nice under load! Full stainless steel and the workmanship is great. It was around Ģ600 but well worth it - you pay for what you get
Post #594951 21st Jan 2017 12:58pm
