![]() | Home > Technical > Gearbox oil change (uk) |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2478 ![]() ![]() ![]() |
Lots of experience (not from the uk though). Puma 110" SW
mse Member Since: 06 Apr 2008 Location: UK Posts: 5107 ![]() ![]() ![]() |
The technique will be the same...just not oil and use? Mike |
The infill hole (about 15mm diametre) is quite hard to get with the Torx 50 and I hope you can unscrew the plug. It is located on the right side of the Gbox and above the cardan joint. I replaced with a brass made with a normal hex head. As for infilling depends on what you have available to pump. Otherwise you can do it by removing the panel under the cubby box and a funnel-hose.
It is not messy to drian as the oil pours straight down. The manual states 2.2 l of GL-4 75W-90 and for sure the infill hole does not match with the proper oil level. Hope it helps. Puma 110" SW ............................................................. Earth first. Other planets later |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
When I did my gearbox oil change, I used a pump, and filled the pump with the correct ammount plus a little bit more.
The oil did pop out of the filler oil a little bit, but that was nothing compared to filling both my eye sockets up when draining the oil out, thanks to a nice gust of wind at the right time. I used the MTF fluid from Opi oils. Both the drain and filler bolts were buggars, not enought room to get a socket/wrench in there so it was a spanner job. |
