![]() | Home > Maintenance & Modifications > VCV + BAS - found the missing horses AND it sounds better |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4293 ![]() ![]() ![]() |
I have this job on my outstanding list. Had the new VCV sat on a shelf for ages. I've finallly found a mechanic who has the tool to do a pump learn, so I'll get this done soon.
Do I need to tell him to do the injector pilot correction learn thingy too? 2007 110 TDCi Station Wagon XS |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Well I'm hardly a qualified LR mechanic but yes all infos I've read so far indicate these processes usually come as a pair.
The mechanic probably knows there job but some extra info is that the engine coolant level has to be between 80 and 75deg - i.e. you've got to let it cool down a bit after a drive and then get to it quickly (if it's cold like it is up your way). Hopefully they can 'probe' this with whatever diagnostic they have. The VCV 'learn' is quite dull but short, the pilot learn is more interesting, the ECU takes control of your car for a minute or two and revs it, seems to be trying to find a nice set of results from certain test inputs. You'll have looks on the street if you DIY ![]() Meanwhile, I'd seriously compare the mechanics quote with the cost of a BAS remap... (and no I'm not employed by them, just a happy customer ![]() |
The mechanic has never done it before, we plugged his diag tool in to check it had the option to do it, but we'll be figuring it out together. Hence he isn't charging much. 2007 110 TDCi Station Wagon XS
Sounds like a good situation, I like it when they're happy for you to stick around
