![]() | Home > Td5 > Best clutch recommendation and best place to buy? |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
Hi guys looking for recommendations on best clutch to get for my td5 as it is nearing its end is it worth upgrading. From standard etc and where is the best place to get it from price, service etc
Thanks Andy ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6039 ![]() ![]() ![]() |
I got mine replaced with a Valeo pressure plate, friction plate, LR release bearing, LR spigot bearing and has been fine. Also replaced the Dual mass flywheel at the same time.
Got the bits from and LR dealer on Ebay http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...Sw~uhUq94c Other suppliers/makes are available 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 291 ![]() ![]() ![]() |
Try these, seems to get good results on Facebook
Clutch Fix Ltd Unit 4, Highfield Works, 44-50 Heaton Street, Cleckheaton, BD19 3TN 01274 877322 NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
+1 for clutchfix speak to Ben Williams he will sort you out they have several options for td5 and puma dependant on what you use it for 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
Oh I can see this getting costly I have already been upgrading power with larger inter cooler, egr blanking Griffen sports exhaust and plan to get it remapped at some point so I am am thinking getting something like the rakeway stage 2 kit would be good idea what do clutch fix do similar any ideas
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1457 ![]() ![]() ![]() |
You don't have to go the rakeaway route to run big power ! Mine runs a standard valeo with no problems. I changed it 18 months ago, but that was down to the squealing thrust washer
dan_the_v8man Member Since: 25 Jan 2017 Location: Sheffield Posts: 3 ![]() ![]() ![]() |
I've got a D2 running 230bhp 440Nm through a standard Valeo DMF and it just about handles it.
Another +1 for Ben Williams at Clutchfix, really knows his stuff, great guy to deal with! |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 732 ![]() ![]() ![]() |
I used a Valeo clutch pack and DMF on the 110 and it seems fine, certainly no slipping. Td5 110 with stage 2 remap etc
