![]() | Home > Maintenance & Modifications > Anti-clockwise torque wrench |
breaker bar to remove bolts not torque wrench
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
http://www.halfords.com/workshop-tools/too...h-60-300nm
I've had one of these for years and has been brilliant, already used it about 6 times this year!! The head pushes out and swaps sides. QRZ 2e0vpf |
Dreamweapon Member Since: 19 Dec 2016 Location: Hessische Odenwald Posts: 55 ![]() ![]() ![]() |
A breaker bar could snap a glow plug, drilling it out is then a bit of a pain in the bottom, the glow plug manufacturers publish the shear strength of the plugs, so using the correct setting on a torque wrench anti-clockwise you don't have to exceed the shear strength and snap the plug (in theory ![]() |
So when you've taken it up to it's shear limit and it still hasn't cracked off what choice have you got then?
Oil in the plug wells for a few days, a hot engine and an extractor kit at the ready
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 589 ![]() ![]() ![]() |
You need this type for on/off torques
http://www.ciponline.co.uk/air-and-garage-...oColHw_wcB ![]() |
Matt90 Member Since: 12 Jun 2016 Location: Leicester Posts: 142 ![]() ![]() ![]() |
I use a "Snap on torque o meter" for jobs like you describe, mines getting on abit and could probably do with recalibrating but I'd rather use this than a breaker bar
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 ![]() ![]() ![]() |
I believe these are made by Norbar (no PROOF one way or the other but I have seen many references online.) Certainly seems good quality and good value ![]() Last edited by apt100 on 19th Jan 2017 12:48am. Edited 1 time in total |
Greg L Member Since: 30 Sep 2013 Location: Alexandria Posts: 46 ![]() ![]() ![]() |
https://www.cromwell.co.uk/shop/hand-tools...stBid=tztx
In work we use this style where the 1/2" drive pushes through allowing both directions. We use it for bolts that have counter clockwise thread. Greg |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1787 ![]() ![]() ![]() |
All the torque wrenches I've ever used have a reversible ratchet, same as all the ratchets I've seen!
Teng do a nice 1/2" one, about �50 from amazon. Agreed with the point about what happens when you reach the shear point. Sometimes no amount of oil and warmth will help! |
