Home > Td5 > td5 - occasional 'groan' initially in reverse |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2884 |
I had a 2006 td5 which did this it was the release bearing nothing to worry about went on for 45000 miles till i sold it cheers chris
16th Feb 2011 12:10pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Mine does it occasionally when starting from a cold overnight stop.
Had a new gearbox a while back. Made no difference. |
16th Feb 2011 1:11pm |
Alive Tuning Member Since: 01 Mar 2010 Location: Louth Posts: 609 |
It's common to Disco 2 and Defender.
We normally fit genuine LR clutch kits, and they do this from new. It's embarrasing when we reverse the car out of the workshop to hand it back to the customer. Only happens in reverse of course, as that's the only time you'll ride the clutch. |
16th Feb 2011 1:50pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Thanks all for replies....
Added to my list of items entitled 'It's a defender - deal with it' On a steep learning curve so appreciate all the help Jon - 110 td5 [sold]. Currently Defenderless. |
16th Feb 2011 2:05pm |
Setok Member Since: 16 Jan 2009 Location: Helsinki Posts: 417 |
Thanks for starting this thread. I have this exact same symptom when cold, with it going away after a while. Good to know it's a case of "a Landy thing".
16th Feb 2011 3:23pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Flywheel spigot bush. Nothing to worry about unless it gets really bad. They all do it
16th Feb 2011 8:35pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 999 |
and forwards too |
16th Feb 2011 8:46pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
clutch release bearing.
good job i'm going auto! |
16th Feb 2011 8:50pm |
Happened tonight on mine taking off in 1st gear.
17th Feb 2011 12:56am |
We fit these as a matter of course when doing a clutch kit. Makes no difference. Yes, it will groan in 1st gear too, but you don't normally tend to ride the clutch in 1st like you would in reverse. |
17th Feb 2011 8:57am |
SteveNorman Member Since: 16 Sep 2008 Location: Somerset Posts: 18 |
Spigot bush.
We soak the new ones in oil, leaving a batch of them in oil until they are used, the bronze soaks the oil in & then when fitted, they don't 'groan' Have fitted many like this, & none have made a noise since Regards Steve |
18th Feb 2011 3:54pm |
