Home > Puma (Tdci) > Leak in centre of door - NOT seal?
kbf1981
I've got a leak coming through the actual passenger door system rather than being a leak on the seal (I think).
When it's been raining you see water:
1) at the Base of the passenger seat, not in the footwell but on the carpeted base of the seat, at the front left of the seat box.
2) also on the door card directly next to this point, with a couple water drops underneath it.
From this it seems the water is coming through behind the door card. No idea how. Has anyone else seen this before and know how to fix it? Car is under warranty but if it's a quick fix I may as well do it ha!
Pics attached.  Any more pics needed please let me know.
Post #593218 15th Jan 2017 1:15pm
kbf1981
Pic not uploading from phone will upload later.
Post #593219 15th Jan 2017 1:17pm
dorsetsmith
Condescend on the under side roof metal work runs down on to the head liner and out in side and down window as the spring are long in the driver side you see it on passenger seat
had same problem in my pick up cold weather i.e. -7 c at night and day time + 7 c removed head lining 1/2 pint of water later dry it off 2m of 7mm foil back self adhesive thermo acoustic closed cell foam and head lining sag fix Thumbs Up
Post #593229 15th Jan 2017 1:57pm
kbf1981
Here are the pics - my roof is that suedy material, and it doesn't feel cold or wet so not sure it's that? I was thinking is it running down a crack in the window and through the actual door inside?
Post #593250 15th Jan 2017 4:16pm
kbf1981
You can see on the top pic when I've taken the carpets out over night... there's zero rain in the footwell, but there is rain / water on the carpet at the base of the seat. The footwell was completely dry, yet the carpet at the bottom of the seat looks to be where the water is first hitting?
Post #593252 15th Jan 2017 4:18pm
dorsetsmith
Running down a crack in the window ?
Post #593258 15th Jan 2017 4:32pm
Balvaig
First check that the drain holes in bottom of door are not blocked.
If clear then you are probably going to have to take the door card off and check that the vapour barrier is there, and not split. The window seals are generally apretty poor fit.
Post #593281 15th Jan 2017 5:33pm
kbf1981
That makes a lot of sense... I had the Defender rust proofed and they sprayed Waxoyl in the doors I remember (or whatever the appropriate thing was if not that). I recon that's probably covered the drainage hole and hence why it's leaking in.
Do you have a picture of what the drainage hole will look like, so I can investigate and clear myself? What's the best thing to clear it, pipe cleaners?
Post #593357 15th Jan 2017 8:44pm
Balvaig
Have not mastered photos yet on the forum.
Not difficult to find though. Three holes just behind bottom seal, front middle and back if I recall correctly. I used a pencil to clear mine.
However, the problem may still be the vapour barrier if the rust proofers removed the door card to spray and then did not reseal the barrier.
Start with the simple and check the holes first.
If you search on this site for 'waterproof defender doors' you will find a useful discussion.
Post #593459 16th Jan 2017 9:29am
pjb
I actually have a similar senario - thank you forum Thumbs Up another irritation that hopefully can be sorted easily 2020 P300 HSE
Post #593488 16th Jan 2017 11:14am
Rattys
United Kingdom 2015 Defender 110 Puma 2.2 USW Santorini Black
The doors are designed to let water in, I've had lots of issue with my first tdci, with water coming through the doors. Behind the door card is a barrier that is designed to keep the water inside the door and direct it downwards. The bottom of the door has a few drain holes to allow the water out. 1954 86" - makes any green lane seem as long as the trans american high way
2015 110 Utility - will have to go and travel the trans american highway
Post #598222 1st Feb 2017 9:45am
