Home > Tdi > 300tdi coolant hose diameter
LCJ
I need to replace the bottom radiator hose on my 300tdi - the water pump pulley has worn though it somehow..
The bit that's worn is the thin tube which feeds into the pipe running across the top of the engine. It's the shorter of the two narrow pipes forming part 5 on this picture: http://www.lrparts.net/discovery-1-cooling...asket.html
My existing pipework is three parts rather than the all in one variety so I'd like to just replace the worn bit rather than all of it.
Does anyone know the dimensions of this piece of tubing (I/D and O/D ideally) so that I can source a replacement?
Thanks very much!
Post #592722 13th Jan 2017 11:27am
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Yip, its 18mm I,D.,, that's the one that supplies heater, [ fits to metal pipe run on top of engine,] just measured an old one , so could be 19 mm, Cool
Post #592939 13th Jan 2017 10:56pm
LCJ
That's great, thank you very much Bow down
Post #592988 14th Jan 2017 11:07am
