![]() | Home > Technical > Is ATB differential dangerous? |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
Never had an issue in snow or ice with mine, in fact I have never encountered any conditions in which the ATBs have had the slightest negative effect.
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930
No experience of ATB's but on my wish list.
Just wanted to say welcome to the forum. MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
| diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260
blackwolf, thank you for sharing your experience.
Cheers, Delyan |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674
Might be worth sending a PM to TATRA805 on here it was his post that covered his experiences, his feed back would be appreciated by all on here, I have 2 ATBs waiting for me to fit them to my 90
PS interesting that the defender leaves you walking home, is this because its broken or stuck DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy Last edited by LR90XS2011 on 14th Jan 2017 9:12am. Edited 1 time in total |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
I had occasion to use my 110 on wet/muddy grass and have front and rear LSDs .. they worked perfectly .. real four wheel drive
looking forward to fitting mine got them just before a 20% price rise, I'm just waiting for some warm weather and a day or 2 away from a house renovation, although my def dosnt do much I just fancied them based on Tatras, Blackwolf and BP mans posts, basically a present too myself, I did do a lot of research and could not find any negative comments DEFENDER 90 TDCI XS,
It gets stuck...furthermore TC is useless on mud or snow. I drive often forest roads that are easy if dry, but really challenging when wet (clay type mud) or snowy. Then as steering is not always possible when road is nasty I often slede left or right, meaning the car is tilted to the side and only 2 wheels have traction, of course the wheels with no mass on them. Than you see how useless TC can be and I am always surprised about some "special" vocabulary than comes to mind in this situations.
I know atbs will be much help, but i'd rather leave the car in the field than eventually sacrifycing on road manner. Thats why my question is about on road behaviour of atb. |
| g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967
what tyres? that could make huge difference on mud! My 109 thread
my youtube channel |
I got stuck with MTs many times and each time because there was no grip left or right. But the main driver for upgrades is the reliability of the car. The idea is simple: each time I break sth. I put aftermarket stuff which is much stronger. Therefore my consideration regarding the front and rear dif- to replace them with stronger diffs and to upgrade the halfsfafts and flanges...but one at a time, this will ruin the family budget
| oburrill Member Since: 09 Aug 2014 Location: North Yorkshire Posts: 33
Have you seen this thread?
http://www.defender2.net/forum/topic13545.html |
yes, I read it three times really carefully. right now i tend to install an atb diff in the rear and keepp the front open or some day put a selectable locker there.
| Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000
I have had an ATB in the rear of mine and on road it been totally transparent. No negative affects at all. I fancy one for the front now.
Mine doesn't have traction control - I wish it did, ATB and TC are a marriage made in heaven. |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
I don't have experience with ATB's, but have experience with ARB's, truetrac's and Detroit lockers.
In a side slope situation een open diff is the safest. Yes your highest tyre on the axle wil have the least grip and will spin but your lowest tyre will have grip and tries to prevent you from sliding down the hill. Any traction device that will try to any torque to the lower tyre will make the lower tyre spin to and you will slide down. I know I have experience with that. Click image to enlarge Click image to enlarge 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
My defender is not going to be a trail vehicle and I dont go offroading for the sport...I just have to pass some forest roads for a purpose, and I dont take the defender if my jeep is available. I am not new to offroading, but new to defenders...have mine for two years now. bought it for long trips with the family, kids love it, so do my wife and I. I didnt want to make serious upgrades to it but I have to, because this vehicle is a bad quality. I started with that puma engine as my turbo died at 50k km...EGR flyed away, cat followed it. Then it was the output shaft of the gearbox, then the center diff...as you can see I work my way down to the diffs and they will be replaced soon together with the halh shafts and drive flanges, wich are badly worn too. And if LR part dies, defender has now 75k on theclock,I defenitely wont bye another from LR. So, soon I will be replacing this diffs, just doing my research what other people choose. I already have experience with arb in my jeep, they are strong design but dont want them for the defender because of the trouble I had with air leaks in the past.
