![]() | Home > Puma (Tdci) > Oil level in the sump (Installation of electric oil heater) |
| Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113
Today I put the heater on a timer at 6:30 till 8:30.
Oil pan was around 14c and the ambient temperature was -3c. Puma started better with less smoke ! I call win, but I am considering an aditional 250 watt pad. Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Any pics of the install? Ray
| VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512
Wouldn't it be more effective to install an electric heating element in the cooling system? Some have built in little impeller pumps so the the heated fluid is circulated and the heat is better distributed to the engine... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
I will after the snow melts A water heater will be more complex and expensive , also it uses more energy then this. 2Kw vs 250watts The big advantage to the water heater is that the top of the engine and the interior gets better heat. but your 8 liters of oil in the sump is still thick and cold. It is the most easy way to preheat the engine. Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
If I were to fit a water heater again, I'd go for the 7 design 240v heater, heats the water jacket and pumps around the engine all for about £100 .. you need mains but a significant saving over a tried and tested webasto
| ob1conobe Member Since: 10 Jan 2014 Location: Gloucestershire Posts: 52
How does this link in with regard to a Webasto (or equivalent) system. I thought that was supposed to warm not only the engine but the cabin also? Is that correct?
