Home > Technical > replacing wheel bearings.
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
To replace my wheel bearings what parts other than two wheel bearings do I need?
I was looking at getting just the two tampered bearings, but looking on my local specialist Web site they offer full kits with bolts seals lacking washers etc.
Is it all needed? I'm guessing seals may be required. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #592508 12th Jan 2017 6:29pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
The best advice I can give is to get a maintenance manual.
Read it and see what they say must be replaced and what might be a problem.
Then order the parts.
That would be the safest way.
Post #592526 12th Jan 2017 7:39pm
agentmulder
Kuwait
If old vehicle with 2 nut system, ideally need new tab over washer per wheel. If new vehicle ideally need new stake nut per wheel.
You'll see why when disassembling.
If you're mechanical enough I suggest converting to more 'refined' 2nut system.
May as well look at replacing rotors at the same time if they need it. Similarly seals, but you don't have to if you're careful. Solved the bowel problem, working on the consonants...
Post #592537 12th Jan 2017 7:59pm
Maris Widgeon
England 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Easiest way is to buy a wheel bearing kit from one of the many suppliers , which will include the seals,gaskets, etc, that is needed to do the job . Not usually much more expensive than just the bearings on there own.
Nick
Post #592538 12th Jan 2017 8:02pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
When I replace my wheel bearings,I always replace the inner seals,1 per wheel.As has already been said,the tab lock washer & the paper drive flange gasket,though you can use sealant.
Thumbs Up
Marc
Post #592546 12th Jan 2017 8:45pm
Retroanaconda
The problem with the kits is that they often have Censored bits in them, you'd be better to take a match to the thing than fit those.
I use Timken bearings, Corteco hub seals, and Bearmach tab washers/drive member gaskets.
Post #592548 12th Jan 2017 8:50pm
agentmulder
Kuwait
^agree
And yeah I totally forgot the flange gaskets! Often you get more than 4, no harm in that...
Yes read the WSM (workshop manual), links found all over the net. Personally I read it over and over until I've got it in my head and only check it for torques from then on.
Item 7 here is the seal that you should ideally get:
Assembly 9 shows the 2 nut system - because of this the spacer washer between the bearings (6) isn't present, if you do have the spacer/stake nut system then make sure you don't mix and match parts between assemblies.
Item 12 are shims (plural) that allow for wear in the plain thrust bearing (15), you could if you like check them out too, but most forget about it with no issue...
It's all in the WSM Thumbs Up Solved the bowel problem, working on the consonants...
Post #592554 12th Jan 2017 9:16pm
jst
2 x nuts, 1 x lock tab, 1 x rear seal (item 7 ^^) 2 x bearings , some RTV
if you have stake nut you can convert to above with those parts and use the stake nut washer to hold outer bearing in place.
if you already have the 2 nut system then del the two nuts above. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #592583 12th Jan 2017 10:17pm
miker
Personally I'd stick with the Stake nut. Quicker & easier, and a lot of people don't set them up quite as well as they think they do!
I know there's the possibility of different spacers, but the consensus seems to be that with timken bearings the original spacer works fine in 99% of cases.
Post #592607 12th Jan 2017 10:56pm
agentmulder
Kuwait
Mine came with different spacers from factory.
Considering the range and step size of the spacers it could be considered very tight tolerance stuff (depending on your industry). I guess the question is: are we dealing with LR hub tolerance, Timken bearing tolerance, or both, combined with installation process...
Personally, I'd rather fart around with depth gauges and torque wrenches than just trust (or have to order a full range of spacer options).
But if people's trucks are trucking then yeah, all good Thumbs Up - i.e. the spacers account for LR hub manufacturing ( Rolling Eyes ), and Timken make a consistent enough product... Solved the bowel problem, working on the consonants...
Post #592619 12th Jan 2017 11:14pm
miker
That seems to be the case! Done both my fronts and reused the original spacers. I don't claim to know all that much about wheel bearings (press in assemblies on all my other cars!!), but my dad, who's a time served "old school" mechanic, did it with me and felt that they were running perfectly. When torqued up, the stake nut rested in exactly the same place as the old as well.
Post #592624 12th Jan 2017 11:25pm
gazman
Thanks guys, I've done tappered bearings before and i've been watching youtube videos so i'm sure I will be ok.
I think I will get full sets as their doesn't seem much point in doing them again in a few months because the seals are ruined. 2014 - current ..... 2003 defender td5 90 (my car)
Post #592648 13th Jan 2017 12:14am
Conan
Belgium 1996 Defender 90 300 Tdi HT Coniston Green
I had to replace the seals on my swivel balls a few months ago. While doing it, I realized I had to replace bearings in one wheel.
these two videos helped a lot:
&index=8&t=6s&list=PLsbuJYez6dIHiX8gJAuhAvTxSG002HBWA
&list=PLsbuJYez6dIHiX8gJAuhAvTxSG002HBWA&index=9
Post #592716 13th Jan 2017 11:02am
