![]() | Home > In Car Electronics > Absolute noob audio enquiry |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1455 ![]() ![]() ![]() |
You may be lucky, and it be a simple unplug/plug in job.
![]() Worst case they might have to cut and splice the new loom in. In any event as long as the new headunit is new boxed and sealed it will come with the correct loom to wire into the vehicle ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
For a 2008 Puma it will have DIN ISO wiring connectors as standard.
This will match the Alpine, or at least should out of the box. Defender - male plugs. Alpine - female connector. If anything more simple than many cars out there as the 1 DIN slot is present with no fascia adapters needed nor any wiring loom adapters. Post 2012 of course you do need a loom adapter. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
petestaunch Member Since: 19 Nov 2016 Location: Wales Posts: 65 ![]() ![]() ![]() |
Thank you both. Really appreciate the help
Pete |
Buz Member Since: 24 Jan 2014 Location: Forest of Dean Posts: 238 ![]() ![]() ![]() |
You may find this interesting:
http://www.defender2.net/forum/topic51768.html |
