![]() | Home > Maintenance & Modifications > Hot Running water in a 110 ? Whats the options |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
someone on farce book was raving about these
https://www.leisureshopdirect.com/gas/cara...pare-parts My 109 thread my youtube channel |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 798 ![]() ![]() ![]() |
One of these was fitted in the rear door of my 110 when I first bought it. Probably the easiest solution
http://ncass.org.uk/store-area/products/ha...ndeman-12v Chris |
Inigo Member Since: 13 Nov 2011 Location: Kent Posts: 625 ![]() ![]() ![]() |
I bought a Webasto system from someone who was going to run a hot water window cleaning service. Standard Webasto with an additional water/water heat exchanger with a thermostatic valve. Never quite got around to fitting either.
Was toying with the idea of teeing the heat exchanger into the coolant lines directly, but then thought that having the V8 running while trying to have a shower/wash might be a bit loud. Link to heat exchanger: https://www.butlertechnik.com/installation...209a-p1516 |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7923 ![]() ![]() ![]() |
A lot of the utility company vans have hand wash facilities such as http://www.tealwash.com/shop/compact-classic-motor-vehicles/
But thinking you might be wanting a little more than this? James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
![]() Chris, have the same but different make in the back of the rally van,, thinking wing tank and plumbed in system for shower etc G-mack,, Usefull link,, ![]() Main Brian James Trailer Dealer for South West UK |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8264 ![]() ![]() ![]() |
that webasto heat exchanger could just be plumbed straight into engine coolant system then? so engine running or TermoTop running means hot water.
would need a 12v inline pump for the fresh water feed, ideally on demand a guess. good thread Tim, need to sort this too. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
http://www.gaelforcemarine.co.uk/en/Whale-...tedKingdom Cheers
http://www.hotcampshowers.com/vehicle_mounted_shower Cheers
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3823 ![]() ![]() |
Our caravan Had a Truma water heater could you get some second hand bits from a caravan?
It also had a water storage unit, It wasn't that big from memory and worked very well. https://www.truma.com/uk/en/water-systems/...ystems.php Thanks |
possible cheap solution, conventional heat exchanger from house boiler second hand plumbed with t pieces into engine coolant system.
whale submersible pump into jerry can to feed fresh water output through household std shower lead. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
you could connect up garden type hose fitting with spray gun for hot freshwater side of it?https://www.amazon.co.uk/Expandable-Pamper...&psc=1 Cheers
that webasto link doesnt show how its mounted or seem to have any mounting points showing?
laminova as a heat exchanger? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
https://www.defender2.net/gallery/thumbnails.php?album=646
https://www.defender2.net/gallery/displayi...&pos=9 Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
I intend to add a heat shot heated wash jet system to a tank and pump. Won't give much just the same as washing your window but hopefully enough to was hands when out
