Home > Maintenance & Modifications > very quick and dirty handbrake adjustment
xcentric
read a lot about adjusting the handbrake - would I be right in thinking at a really quick and dirty approach would simply be to turn the adjuster on the transmission a quarter turn at a time, to change the handbrake from just on at fully upright to engaging at the lower end and being at after 3 clicks?
would save the (minor) hassle of jacking it up (given where my vehicle is) and seems to have the same end effect.....? or am I missing something?
Post #591366 8th Jan 2017 8:03pm
roel
I always do it that way before the APK (MOT).
My procedure:
Put the handbrake on to see how many clicks I have. Take the handbrake off.
Get under the 90 with the right socket. Oops wrong one, get the right one. Twisted Evil
Get under the 90 again and tighten it and lossen it again 1 quarter.
Get in the 90 put the handbrake on again and check for the clicks.
Take the handbrake off again a drive a little to hear if it makes noices and off to the APK (MOT). Roel
2003 90 Td5 (2009-now)
Post #591623 9th Jan 2017 8:01pm
rossy
Or even quicker is what I do just before MOT time.
Take the handbrake off, get underneath and tighten about 1/2 a turn... er thats it. its usually enough to reduce the travel of the lever just enough - you don't want it too tight and I always leave it in gear anyway.
Post #591933 10th Jan 2017 9:42pm
