![]() | Home > Technical > Wiper issues (changed everything) still problems! HELP! |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Have you replaced the relay?
FLX1S Member Since: 17 Dec 2016 Location: North Wales Posts: 10 ![]() ![]() ![]() |
I did a about 6 months ago with a programable one...
Try sticking the old one back in if they were working properly when you took it out... If not stick a new standard one in & see what happens.
Old one went in the bin, so just ordered a Lucas one...
Thanks, I'm guessing its all it can be? |
May have got a dodgy park switch. Ray
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Have you tried hitting it and swearing a lot? I find it doesn't necessarily fix the problem but it does make you feel better for a bit.
Cables? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Relay changed, and no change. Still doesnt park or work on intermittent!
Hitting and swearing now starting! Anymore ideas? Cheers |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 688 ![]() ![]() ![]() |
Take the park switch off but leave the cables connected. Operate it manualy to see if it works while the wipers are running.
This will show if any issue between the gears and the park switch. |
Ray My build thread http://www.defender2.net/forum/topic17615.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6682 ![]() ![]() ![]() |
What does work with them?
Do they wipe when you wash? Do both speeds work from the stalk? ![]() ![]() |
they wipe on both speeds, don't park, nor work intermittently.
They don't wipe when you spray the washer either. I'm thinking wiring! |
Froglaise Member Since: 24 Sep 2016 Location: left forum Posts: 212 ![]() |
Not much else to change so must be a wiring issue.
Did you add/change anything on the vehicle before the problem started? |
