![]() | Home > In Car Electronics > Heated mirror/front screen switch issue |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
Cheapest and quickest option is 3 - the Puma heated seat switch will do what you want.
jr1104 Member Since: 05 May 2016 Location: England Posts: 78 ![]() ![]() ![]() |
I'm in the process of planning something similar (one switch for heated front/rear/mirror). In choosing the relay(s) for this, a timed one made more sense for functionality? That way I press it once, and I don't have to remember to turn them off again after driving for a while.
PRC6796 is the original fit timer for the front screen, it normally operates a single relay for the front screen but you could add extra relays
Hmm, they used to come up on eBay regularly but seems that's no longer the case
drinkdrinkdrop Member Since: 13 Sep 2016 Location: Surrey Posts: 76 ![]() ![]() |
I'll go with that then, thanks for your help |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 438 ![]() ![]() ![]() |
Slight Hijack of thread
I would like to put heated seats in on a timer - 10 mins heat at start of journey If I use the front window switch to a GLR10 timer then a relay - will this work The kits from mobile centre seem to have two relays and the orange timer - why two relays Any chance of someone showing the wiring required ? |
