![]() | Home > Maintenance & Modifications > LED indicators and brake lights |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20843 ![]() ![]() |
LED's are much more sensitive to voltage spikes, fluctuation in voltage and earthing.
I'd say the later may well be a cause, try adding a temp earth and see how things work out. Whilst at it do some continuity testing. If all checks out and no effects from doing so it's power feeds that'll be the issue. Are all connectors in good condition? Earth straps clean, tight and with low resistance? _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Try disconnecting the towing socket, if you have one the plug is under the drivers side rear wheel arch at the back, these can corrode inside and cause all sorts of electrical gremlins. Ray
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6669 ![]() ![]() ![]() |
No tow socket plug on an 1987 vehicle..
Didn't know that
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2343 ![]() ![]() ![]() |
But there my be a birds nest of rotten wiring and corroded bullet connectors from an old socket.
Towing connections on a LR of that age are made behind the upper lamp covers, so better protected from mud/water.
It may have a hard wired tow socket fitted if any, it could be taps into the light feeds or the two socket.
That's of course if there is one present. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5123 ![]() ![]() ![]() |
I hope this helps.
I changed all my exterior lights on my Defenders to led both TDi and TDCi. On the TDi both 200 and 300 engine types I found that the lights did not work properly with the relay supplied by WIPAC or the RDX relay (a known problem). On the TDi I had to obtain a special trailer earth warning light supplied by Bolt on Bits, you have to phone Bolt on Bits and ask for it to be sent to you as it not listed on their eBay store. Then you take out the original trailer warning light and install the RDX Bolt on Bits new trailer light bulb and attach the earth wire attached with the new trailer warning light bulb to a good earth and all will be fine. On TDi 200 and 300 variants the indicator lighting circuits earths through the warning light bulb and causes all sorts of problems the Bolt on Bits fix does away with any problems you have. Bolt on Bits phone number 01274 688388 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
gilly1969 Member Since: 16 Mar 2016 Location: Godstone Posts: 48 ![]() ![]() |
Hi everyone. Thanks for the amazing feedback. RDX relay switch arrives tomorrow and I've already got an appointment with the garage to get the brake lights looked at. I'll mention everything you've suggested and post back to let you know how I get on and as to which approach worked. It's been doing my head in! Thanks again.
Weird. I changed to all RDX indicator with RDX Relay on my 300Tdi. Never had any issues, and did not have to use special warning light (did not even know about that)... Indicators work fine just tune the knob on the relay so the warning light only lights up once when not towing. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Chris90V8 Member Since: 02 Oct 2016 Location: Suffolk Posts: 714 ![]() ![]() ![]() |
...feeling your pain
Type in the search bar for " Indicator fault " Just went thru all that indicator gremlins Will help ![]() |
Here's an update. Garage fixed brake issue. Turned out to be a faulty switch somewhere. RDX indicator relay switch with regulator turned down until trailer warning light goes out seems to have fixed the indicator problem. Relay switch was adjusted with engine running. I'd read somewhere that running at full power is more accurate when adjusting. Thanks for all the feedback. It was really helpful. On to the next problem!
Good it's sorted!
Cheers ![]() 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Thanks for the update
