Home > Wheels & Tyres > wheel spacers - again....
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
Hi folks,
I recently obtained some 30mm alloy wheel spacers to try on my defender 90.
They do not have the small hub centric flanges on that I understand should be in place when spacing out alloy wheels.
Will it be safe to try these out?
Advice appreciated folks.
Post #584568 12th Dec 2016 8:56pm
Smithy
Hi
Those spacers are for steel wheels.
The spacers with the location lugs are for alloys.
Post #591006 7th Jan 2017 5:12pm
Disco_Mikey
Scotland 2009 Defender 110 Puma 2.4 DCPU Keswick Green
They are suitable for both types of wheels, just the ones without the centre flanges tend to be of a cheaper manufacture
Post #591012 7th Jan 2017 5:38pm
grafty99
I ran spacers for around 12 months, I was never fully happy with them and they were always in the back of my mind (I have since changed to an offset wheel).
They were hubcentric ones - I wouldn't be happy with all the forces a wheel is put through to go solely through the studs of a 30mm block of aluminium bolted to the hub.
Having said that I have never heard of a spacer failing so maybe my justification is unfounded Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #591015 7th Jan 2017 5:45pm
Pickles
Spacers are illegal in Aussie.
Pickles.
Post #591078 7th Jan 2017 9:13pm
JOHNT01670
Haven't fitted them yet....
decisions... 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #591118 7th Jan 2017 10:21pm
Sulisuli
Have had spacers and smaller steering wheel on my defenders for last 10 plus years to improve turning circle on three different versions of 90s without any problems, fitted them during warranty period as well and main dealer even kindly altered bump stops to improve the turning circle for me to get the most out of them.
They have just put spacers supplied by me onto my current 90Xs HT when they took the wheels off to balance them for me and its within warranty still Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #591124 7th Jan 2017 10:36pm
Stacey007
I have not got any but if I did (and I will at some point)
Go for the hubcentric ones they are supposed to be much better and less chance of any vibrations.
I'm sure years ago Porsche used spacers on the 944 and other models... If they are good enough for them then I guess on a Defender they should be ok?
Post #591129 7th Jan 2017 10:52pm
JOW240725
I've run 30mm spacers for nearly a year now no problems but... they are good quality hubcentric. The mere fact you are doubting them woule rule them out for me. James
Instagram @suffolk_rovers
Post #591138 7th Jan 2017 11:06pm
Stacey007
They sound like the type I used to put on original mini's
Basically a big washer..... Fine I would think on a 10" mini wheel given the mini I had probably struggled to have 40bhp Smile
I would not put that type on my truck...
Post #591142 7th Jan 2017 11:17pm
Bps
I have used the plain ones before and never had an issue. I couldn't fit the hubcentric ones as my back axle was had the big mushroom head shafts on so they wouldn't fit.
I made sure hub face was nice and clean, thread locked the spacer to hub bolts and I never had an issue with 35" tyres and 3.9v8
I checked the spacer nuts after 1st day and then 2 weeks, then every 3 months. And never had to tighten at all
Post #591188 8th Jan 2017 9:35am
Fat Cog
Don't forget to inform your insurers, dependant upon insurer they can get can quite alarmed by the use of them; personally I'm not a fan of them and quite recently a buddy of mine bought a Defender with them on and his insurer refused to cover the vehicle until they were removed! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #591198 8th Jan 2017 10:06am
Disco_Mikey
But they sit so much better on them Cool
Post #591225 8th Jan 2017 11:59am
grafty99
I agree the stance they provide is very nice Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #591353 8th Jan 2017 7:32pm
Which just tends to confirm how staggeringly ignorant insurers tend to be.
Post #591461 8th Jan 2017 11:18pm
