![]() | Home > Technical > Spigiot bearing removal!!! |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
I would love to know as well. I have heard of specialised slide hammers etc but my local garage recommended a chisel.
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I've got the proper slide hammer but it wouldn't touch it
![]() I've now got half of it out, and done about 3 chisels in! It had got so hot, it's practically welded to the crank..... ![]() Wanted, Forward Control Anything considered. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8402 ![]() ![]() ![]() |
i like the notch bolt idea Cheers
Thanks very much for that Dorset!
I didn't want to damage the rear of the bearing, but now know I'm able to drill through the back of it is good news! I couldn't get a new one until tomorrow, so wasn't sure if the back was part of it? I will use that method tomorrow. That's a great help, cheers ![]() Wanted, Forward Control Anything considered. |
no problem good luck
Now removed
![]() Drilled through the back, pulled it out with a slide hammer. Thanks again for the link Dorset. ![]() ![]() Click image to enlarge 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
