Home > Puma (Tdci) > Fixing diesel knocking at home.. Possible?
agentmulder
Kuwait
Hello all,
I have a 2.4 puma with a bit of knocking noise around certain RPMs, it’s never quite the same each drive, but enough to make me want to do something about it if I can, so I'm iInterested to learn what I can do to reduce it with what I have on hand.
Firstly, I’m about to order some new bolts for my injector retaining clamps due to this issue just fixed this AM:
But while I was shopping I also noticed that new injector seals weren’t going to break the bank so figured why not get some too, people seem to talk about them often...
Question: is replacing the seals easy? is it recommended for this, recommended regardless or asking for trouble?
I should note that I have the (brilliant) BAS 150 remap that includes the RR2 tool that can do the following:
- Pump VCV
- Pilot correction
and if I recall correctly there is also ‘injector learning’ or similar in the menu.
Some of these options apparently eat up your ECU memory however so I don’t want to play with them willy nilly.
Lots of discussion on the net, snake oil merchants - ‘it’s not a problem!’ and so on .. Keen to hear from people in similar circumstances who have achieved success with this at home, especially if they can make some engineering sense out of it. Solved the bowel problem, working on the consonants...
Post #590015 4th Jan 2017 11:25am
enfield_dinosaur
2007 Defender 110 Puma 2.4 SW Java Black
Hi!
I have the same issues as you and will get four new injectors tomorrow. I also intend to have the seals replaced. Copper gaskets have been already done.
Did you already check the injectors return flow of diesel? If they are out of tolerance, that's a good indication for them being the culprits.
Will keep updated on how my operation goes.
e_d
Post #590017 4th Jan 2017 11:32am
agentmulder
Kuwait
Four new injectors - wow $?
What is the difference between the seals and copper gaskets?
Maybe I need to read up more on this! Solved the bowel problem, working on the consonants...
Post #590038 4th Jan 2017 12:34pm
enfield_dinosaur
Yeah, might be slightly overkill. But 1+3 and are slightly out of tolerance alrerady, my car has 70k miles on it. They'll be done for sooner or later, and all repairs surrounding the injection system are rather pricey, as I found.
I had the copper gaskets fixed already. The gaskets are worth pennies, but the procedure was was £ 850 (Problem is, apparently, with the Puma you cannot reuse the fuel lines and have to make it all new again).
And, to my dismay, it did not cure the problem. So everything has to come off once more, new fuel lines, etc. And since I do not want to have to take off everything a third time, I figured that I might as well replace the injectors, seals (as I understand it the injectors have two more rubber seals that can also leak), and new copper gaskets again at the same time.
It's scheduled to be done tomorrow, so if I am wrong, please chip in and let me know before I'll bleed a substantial sum of cash, totally unwarranted...
Post #590043 4th Jan 2017 12:54pm
Rickydodah
I've changed thousands of injectors and have never had to replace the fuel lines before......maybe this is something peculiar to the Puma engine.
I'd be interested to know the reason if anyone can enlighten me Confused I started with nothing and still have most of it left!
Post #590044 4th Jan 2017 1:01pm
enfield_dinosaur
My mechanic says it's mandated by LR that on a Puma engine, removed fuel lines have to be discarded. Apparently the lines are even self-tapping and cannot be put back on even if one wanted.
So they say Confused
Post #590049 4th Jan 2017 1:06pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
There is a recomendation about replacing metal fuel lines, but I have done many using the originals and never had a problem.
I would recommend replacing the small leak off O rings (usually green in colour) or at least have some spare ones to hand, as they are very easy to damage when refitting the leak off pipes. 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #590065 4th Jan 2017 2:27pm
enfield_dinosaur
And this is exactly what I presume happened last time, as my diesel knock got better, albeit persisted, with new copper gaskets.
Said copper gaskets were replaced, but the green O-rings were not.
Tomorrow, new green O-rings and - while were at it - injectors - and then: hopefully all will be well.
I've been driving with a ever so slightly knocking 110 now for a year, muffling it by using premium diesel. But that's no long term strategy.
Post #590067 4th Jan 2017 2:36pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Hi,
Is this based on Puma injectors, or many injectors replacements in general?
I guess if the lines are removed, then your effectively stripping back to the pump, or does it stop at the fuel rail I wonder?
If it stops at the fuel rail, is it not being replaced due to the fact its a forged component and thus very very hard, and not likely to be deformed - I wonder?????
I guess the risk is that the new made connection (using old lines) has a weakness and the chance you could have high pressure fuel spraying inside the engine bay @ circa 1200bar. I would guess its a very small chance, but maybe something LR see as a genuine risk, hence the recommendation.
Andy
Post #590152 4th Jan 2017 7:10pm
enfield_dinosaur
As I recall, it stripped back to the fuel rail. I also faintly remember the rule existing due to fear of contamination with dirt or residue. Apparently, common rail systems are rather delicate.
Post #590153 4th Jan 2017 7:19pm
agentmulder
Kuwait
So:
Mr. Green
Sounds like no? Solved the bowel problem, working on the consonants...
Post #590169 4th Jan 2017 8:08pm
LR90XS2011
Hi Agent Mulder , why are 2 of your injectors in the video jumping about like they are not clamped down, i have a 2.4 and the injectors are clamped solid in the head? DEFENDER 90 TDCI XS,
Post #590170 4th Jan 2017 8:11pm
agentmulder
Kuwait
Yeah, they weren't clamped, bolt worked itself loose, refastened the current one but a new pair in the mail as they are 'torque to yield' bolts.
Hell of a clatter that the video doesn't do justice.
Running as per normal again, but the process got me thinking about what I can do about knocking with the stuff I can access as easily.. Solved the bowel problem, working on the consonants...
Post #590180 4th Jan 2017 8:57pm
ian series 1
Hi,
Andy
Puma Engines/ Transit engines, obviously cleanliness plays a major part in these components, but as long as your carefull you should be fine.
I've never had any issues with leaks or pressure drops, only from leak off O rings which become hardened over time.
I worked on Scania trucks for a while and it was always well documented that the fuel lines were replaced when removed, but generally the customer would not be willing to foot the bill for new lines, (serious money!) so the old ones were reused without issue with the owners consent, and these were running a much higer pressure than a 4 pot diesel.
There was a story of one technician at another depot who had a fuel rail presure valve blow out, which left the fuel rail, through the rads, and grille, and through the workshop wall and out the other side! 80" 80" 86" 88" 90"
Post #590217 4th Jan 2017 9:53pm
enfield_dinosaur
The culprit has been found.
Anybody sees something unusual?
Post #590343 5th Jan 2017 12:08pm
