Home > Tdi > 300 tdi oil pressure problem.
LANDROVER
The other day our Discovery 300 tdi suffered another breakdown.
This time turbo failure with oil pressure light illuminated.
Swapped turbo oil & filter change and still no oil pressure. With switch removed no oil coming out of hole....
Stripped sump & found two little washers. One plastic one steel. Please see the pictures.
We have oil pressure relief and it is intact. Also oil pressure thermostat in filter housing also intact.
Any ideas what it could be & where the little parts are from. Plus there is a little bit of metal in the sump. The engine was running with no knocking....
Big ends show minor wear.
Confused
Post #584193 11th Dec 2016 8:05pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
What about the oil pick up gause, [ on oil pump] did you check it with sump off ?. need to check the output rating of pump also ,
Post #589591 2nd Jan 2017 10:27pm
LANDROVER
Re: 300 tdi oil pressure problem.
Smile
Post #590201 4th Jan 2017 9:25pm
LANDROVER
Thanks for the reply Blackhat90.
We have removed the oil pick up pipe & strainer and it is clear.
We have also removed the timing chest & oil pump and inspected it. It is fine and looks perfect? Also we have removed the oil relief valve and it looks fine and no damage.
How would you test the output of the oil pump? Via pressure switch location?
I would like to know what has caused this issue as it has me stumped.
Thanks again
Post #590205 4th Jan 2017 9:29pm
LANDROVER
Post #590212 4th Jan 2017 9:39pm
L110CDL
Thats a blast from the past Shocked A Leyland tractor, haven't seen one of those for a long time that is still running Thumbs Up Clayton.
Keeper.
Post #590213 4th Jan 2017 9:42pm
LANDROVER
Post #590294 5th Jan 2017 12:54am
LANDROVER
Yeah its still a runner! Its a good tractor and super reliable. We use it and the major all the time. Its amazing how handy they are. Thumbs Up
Post #590296 5th Jan 2017 12:56am
Blackhat90
You"l need to connect an oil pressure gauge, [ fittings can be connected to the oil light switch], mine is putting out, 50 lb/ft ,
when cold, drops to 35lb when hot, 300tdi coverd 330,000 miles,,,never had a spanner on the engine , Cool
Post #590348 5th Jan 2017 12:35pm
LANDROVER
I removed the pressure switch and no oil comes out on cranking or running!
This has done 180,000 but we only recently bought it for my parents. Its a 300tdi EDC auto. Its strange that there is no oil pressure at all and that's why we pulled the timing chest & oil pump to inspect. It has me stumped. So we are pulling the complete engine out. It would be nice to find the problem and kept it as a spare.
Post #590389 5th Jan 2017 3:17pm
L110CDL
Sorry for the divert on your thread Rolling Eyes What Major have you got ? Clayton.
Keeper.
Post #590521 5th Jan 2017 9:41pm
LANDROVER
The Major is a 1960 Power Major. Its my Brothers we use it for wood splitting, topping and with a tipping trailer. Its a rolling restoration....we rebuilt the engine after a major failure! So it has new pistons liners, bearings throughout another head and new valves. We have the badges and new grills but not fitted them yet.
We use them every weekend for jobs at home! They are great tractors.
I have pictures of the rebuild but these are of the piston after the valve smashed through it and resealing the rear main after it leaked after rebuild.
Post #590550 5th Jan 2017 10:33pm
LANDROVER
I like a thread divert like this Thumbs Up
Do you have any tractors?
Post #590552 5th Jan 2017 10:35pm
L110CDL
I have great friends that i use to help on a farm and they had a Power major, super major and one that we called "the six" power major with the six cylinder engine fitted, just loved them Thumbs Up
Yes i have just one at the moment a International B414 and has a front loader and the weight to go on the back, dont use the loader much, had it for about 25 years now Shocked When i first got it, it ran ok but after a year something was wrong, we thought it was the head gasket, so took the head off and gasket was all ok Shocked So it turned out to be the front piston liner, so at that point a total engine rebuild and to this day starts first time every time Thumbs Up I'm hoping one day to put it back to its former glory (when new ) Thumbs Up Clayton.
Keeper.
Post #590559 5th Jan 2017 11:02pm
