![]() | Home > Maintenance & Modifications > Td5 dash |
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
I believe this can be done, I think Martin has done for heated seats…depends if you have headlight leveller switch currently
boode Member Since: 11 Apr 2012 Location: Devon Posts: 438 ![]() ![]() ![]() |
![]() Click image to enlarge Only a USB where the leveler fits |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 735 ![]() ![]() ![]() |
There should be enough room below the radio for switches and enough room behind too.
Heres my dash I modified before I changed to a puma dash. The switches below the CD player worked perfectly and nothing fowled them. ![]() Click image to enlarge I would however, just to be safe, check there is enough room behind yours. As mine was a 300 with complete td5 dash, although on our td5, there doesn't seem to be much where those switches are. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2389 ![]() ![]() ![]() |
I've moved my radio downwards using a Mud panel. If my radio fits there then you can be quite sure your switches will 😊
