![]() | Home > Maintenance & Modifications > Is 4 inches big enough (ooer...) |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
6" 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
Just go slowly with some lube (pentitrating oil/ WD40) if it gets too tight just remove and start again, if you try to force them too much you can crack the cups very easily. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
More importantly than the jaw width is how far the jaws will open to enable the assembly to be pressed together ![]() |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7928 ![]() ![]() ![]() |
So much innuendo
![]() ![]() ![]() ![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Missed that, I assumed thats what we were talking about, even 6" os tight! Left myself open there! ![]() Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
ChrisWoods Member Since: 29 Dec 2016 Location: Spreyton Posts: 164 ![]() ![]() ![]() |
I tend to use a decent F or G clamp with sockets. That way I can lay the rest of the shaft on the bench. Plus you could take it with you on the road. And before I remove, I warm the whole lot up gently and then when it cools the seal is usually broken and the whole lot moves easily with a bit of oil. 2009 2.4TDCi XS Utility Wagon.
Muddybigdog Member Since: 11 Apr 2014 Location: Suffolk Posts: 1047 ![]() ![]() ![]() |
Does the lube have to be warmed up before applications? Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold D3 - 2.7 S x2 (both Sold) Freelander 2 HSE - Sold Freelander 1 - Sold Disco 2 - Sold |
Haha! Innuendo bingo! 2009 2.4TDCi XS Utility Wagon.
v8steve Member Since: 18 Apr 2011 Location: dumfries scotland Posts: 195 ![]() ![]() ![]() |
have found if you apply lube cold it makes for a quicker reaction time.
![]() s3 swb soft top |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
If you get stuck, look online for reference.
But seek approval before making any purchases ![]() Self confessed mileage hunter ![]() |
