Home > For Sale & Wanted > [For Sale] Mantec Swing Away Spare Wheel Carrier
Page 3 of 6 <123456>
Laurie
Mine arrived yesterday, thanks. Very Happy
Post #569474 8th Oct 2016 12:15pm
lmanton
Received safely
Both of mine arrived last week thank you. Very pleased. does anyone know the best place to get the alloy wheel Spacer kits from? Thanks.
Post #570536 13th Oct 2016 10:10am
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Hi, I understand this opens with the rear door. May I know if there is an ability for only the carrier to open (separately from the rear door) as well?
e.g. can I clean the rear door behind the spare wheel by moving the swing career or must the spare wheel be removed etc?
Many thanks!
APK
Post #589806 3rd Jan 2017 6:34pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
This type is attached to the door 1 bolt and can pull it clear but a faf to do it you can get you hand up behind though so not an issue to stay in place 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #589838 3rd Jan 2017 7:41pm
Ayrshirelandy
Wheel Carrier
Dan,
Does this one swing away independently of the door? I have a 110 utility and to connect caravan / trailers I need to keep door open due to spare wheel obstructing.
Thanks
Al 2015 Defender 110 XS Utility Santorini Black, sawtooth alloys, steps and so much more...........
Post #589866 3rd Jan 2017 9:06pm
APK
pj2106 wrote:
... you can get you hand up behind though so not an issue to stay in place
Thanks Thumbs Up
Post #589920 3rd Jan 2017 11:07pm
leeds
Ayrshirelandy, if you are having trouble hitching up a caravan, try a 2" spacer behind towball. A much better solution (not cheap) is using a Dixon Bates shocklink. Improves towing a lot and I would recommend it. If you have an Alko tow hitch with big red handle take the red handle off. Slightly more awkward undoing the tow hitch due to much shorter handle, to fasten the handle I tend to step on it.
HTH and hope Dan does not mind me commenting on his thread.
Brendan
Post #589936 3rd Jan 2017 11:38pm
APK
May I know the difference between this item LR VPLDR0130 and Mantec 214-SWCDEF please?
Are there any structural differences or is it just the LR vs Mantec stamp?
Thanks
Post #591990 10th Jan 2017 11:49pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Can one be shipped to Italy?
Post #594685 20th Jan 2017 11:09am
TOP5N
Hi, are there any of these left for a 2015 defender 90..
Chris
Post #651951 21st Sep 2017 10:43pm
Vintagepaul
2015 Defender 90 Puma 2.2 HT Santorini Black
PM sent Chris. 2015 Defender 90XS HT
Post #651970 22nd Sep 2017 6:08am
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Dragging up an old post here but does anyone have the LR edition of the instructions for fitting this please?
I have a copy of the Mantec instructions but the LR kit is slightly different.
https://thomasperformance.co.uk/downloads/...-print.pdf Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #742429 26th Nov 2018 9:36pm
Martin
Site Admin
I'm going through the same, I discovered the fitting instructions for the Wolf version in a set of MOD documents which had been released under FoI. Honest! Whistle
I've pulled out the pages relevant to fitting the wheel carriers (and converting the tailgate on a soft top). A combination of this one and the Mantec instructions will see it done. It explains why there are the extra bits you get over the retail carrier, and the longer bolts due to the thicker Wolf rear crossmember.
http://media.defender2.net/gallery/albums/...DR0130.pdf
Quite a big file sorry (28MB)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #742503 27th Nov 2018 1:52pm
Stu_XS
Thanks a lot Martin. I think I found the same file in the early hours of this morning and I also had a copy emailed by Dan this morning. Smile
A question though, I'm glad you're in the same boat, there is what seems to be a retainer or latch which is the rubber cup and ball. From what I can see the rubber would bolt on to the back plate using the right angled bracket included. However the back plate will sit flat against the rear door so there isn't the space to fit it.
You can see in the image below it is mounted near the piston but on a raised back plate and not the flat type included in the kits.
 Stu...
Post #742514 27th Nov 2018 3:45pm
X4CAC
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
The door plate looks completely different to mine...
Post #742524 27th Nov 2018 4:28pm
