Home > Technical > Battery problem - urgent help please (sorted thanks)
stricko
Hi
I have just tried to open the car (2010 MY 110) from the fob and nothing happens.
The red light on the dash is flashing.
I used the car yesterday but had to put the battery booster on it to start it first. I then went for a long ish run (2hrs) and it all seemed fine.
Admittedly, the only journeys I have done recently have been short runs to and from the station with AC on etc. So have probably knackered the battery.
I need to use the car at 5am tomorrow.
If I open the car on the key, presumably the alarm will go off?
Have these cars got battery backups for the alarm.
The wife is just looking to see if we have home start recovery, although not sure what they will be able to do to help for tomorrow?
Any help much appreciated ---------------------------------------------------------------
Post #589802 3rd Jan 2017 6:27pm
DAZ110
Unlock it with the key and see what happens. Some models have battery backup alarms and others don't. Depends on the build spec. If your Defender is a 2.2 puma then it probably does have the backup sounder. Good luck. I'm sure someone will know more than me on this.
Post #589808 3rd Jan 2017 6:39pm
stricko
hi
Thanks for the reply
Mine is a 2.4
If the backup sounder goes off, how do I silence it?
I can try and get the booster pack on it quickly to start the engine? ---------------------------------------------------------------
Post #589809 3rd Jan 2017 6:42pm
DAZ110
My money is on the fact that you haven't got a battery backup sounder then.
Sorry I can't be of any further help! Crying or Very sad
Post #589810 3rd Jan 2017 6:47pm
jst
mines a 2.4 10MY with a sounder.
i would open it with the key and jump it. there is a sequence or door open/closes ign on/off to silence the alarm is there not? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #589819 3rd Jan 2017 7:22pm
Are you sure that the fob battery is ok? Try a different set of keys, and hold them close to the driver's side A-post when you press the button.
If the fob is good and the vehicle battery's totally flat, it's likely that you don't have a BBUS (battery backup sounder) since it will go off if the vehicle battery is completely flat. If it goes off, pressing either fob button should cancel it, provided the fob battery is ok of course.
I would try opening the vehicle with the key and seeing what happens.
Post #589820 3rd Jan 2017 7:26pm
the gamekeeper
England 2007 Defender 110 Puma 2.4 DCPU Tonga Green
I have a 2.4 and if you use the key to unlock I'm sure your alarm will sound and you would need to connect the battery and use the fob to reset. Can you not charge it up over night or just leave it unlocked.
Tony
Post #589824 3rd Jan 2017 7:31pm
stricko
Thanks for all your help! http://www.defender2.net/forum/images/smiles/icon_bow.gif
However, I cant believe it. I was about to open it with the key and ready to rush around getting it started to silence the alarm when it went off and I thought I would give the fobs another try. One press and it opened straight away and started fine.
I had previously walked all the way round the car with both fobs pressing at all different locations - in particular near the drivers door.
Both fobs have had the batteries replaced very recently.
It now all seems to work from anywhere. Very odd!
I have now put the battery on a recondition charge with the Ctek charger overnight.
So, thanks again and sorry to have wasted anyones time! ---------------------------------------------------------------
Post #589835 3rd Jan 2017 7:39pm
jst
sort of good and bad news then!
good it worked, bad its intermittent. let hope its ok tomorrow am. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #589839 3rd Jan 2017 7:42pm
agentmulder
Kuwait
Is it possible you used the sequence 'lock, lock, lock, lock, unlock' on the fob just before it worked?
That's the fob resync sequence that I have to use on my 2.4 after having disconnected either the fob or vehicle battery...
I managed to do this randomly the first time I encountered the issue so it it took the second time to actually learn about it. Solved the bowel problem, working on the consonants...
Post #589857 3rd Jan 2017 8:38pm
jst
^^^ didnt know that Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #589870 3rd Jan 2017 9:18pm
^^^^ This is true, but if you change the fob battery fairly rapidly you shouldn't need to do it.
The LR battery you will every time.
Disconnecting the battery is essential before starting and electrical work. Smile _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #589873 3rd Jan 2017 9:33pm
stricko
Well it all worked fine this morning and when I returned to the car this evening.
agentmulder - its possible I could have pressed that combination as I was frantically trying everything in amongst the swearing!
Its a good job it worked today as my other option was a southernrailways Censored train !! ---------------------------------------------------------------
Post #590161 4th Jan 2017 7:42pm
Proof that there is something less reliable than a Landrover! Rolling with laughter
Post #590165 4th Jan 2017 7:50pm
Roosterrs
I had a problem with both my cars one morning. First was a Toyota Rav4, went out and couldn't open it on the fob. Wouldn't unlock and assumed battery was dead in fob so walked to work. 1/2 hour later my wife rings me telling me she can't get in her car, a Mini One. Fob not working. She called the AA and he really struggled to get into it. Cars were fine previously night and OK at night the same day. It turned out after speaking to a few people a communications company had been installing new lines and had been buzzing the lines to test them which we think interferred with both cars.
Post #595017 21st Jan 2017 6:08pm
