![]() | Home > Puma (Tdci) > 2.4 Going into lack of boost mode, CodeP0234 turbo overboost |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 170 ![]() ![]() ![]() |
New MAP sensor and problem fixed..
madfrankie Member Since: 10 Oct 2016 Location: Hertfordshire Posts: 356 ![]() ![]() ![]() |
Hi,
Do you mean MAP sensor or MAF as you changed half way through the chain? "Of Course, Of course, I ain't asking . I'm telling!!" |
Hi it was the MAP sensor I changed,
Mine kept having that until I got the EGR disabled, but I was getting EGR and MAF errors too.
MMR1988 Member Since: 29 Oct 2016 Location: Chemnitz Posts: 54 ![]() ![]() ![]() |
I know the problem is solved. But I have another solution:
I had the same problem. It was a broken cable from turbo connector. /Max |
