![]() | Home > Technical > Circuit Diagram and Part Number |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
Out of interest, where are you sourcing your connector(s) from? Apart from Simtek, who only do the female connector as a kit, the only places I know of where you can buy small quantities of these connectors, are - Deytrade in Germany and Mouser in the US (via their UK website) The connectors are 10-way Delphi Metri-Pack 150 Sealed Series, here's a couple of pic's from the Delphi Catalogue showing how they're assembled and the component part numbers - ![]() Click image to enlarge ![]() Click image to enlarge I hope that's useful. . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 266 ![]() ![]() |
PaulMC
i contacted simtek, and Ginny emailed back and said they keep mthe plug on the shelf as standard, but they can get the other half as well. if not, then i will contact the people you have mentioned and see what i can get from there. out of interest, i am assuming i require an A, 2x B and a C as well as some mail and female inserts? thant you for you help, again, as always, it is very much appreciated. Cheers keith puer claudius |
PaulMC
have placed an order with the coy in Germany. thanks again for the info. Cheers keith puer claudius |
Happy to help ![]() . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 12th Jul 2011 8:34pm. Edited 1 time in total |
Paul
i am about to ask a realy dumb question, but as i am not able to see inside the plug, you may be able to help. when assembling a new plug, do the femail connectors fit inside the femail plug? and vice versa, male in male Cheers keith puer claudius |
Not a dumb question at all ![]() The gender of automotive connectors is denoted by the gender of the terminals, rather than which housing fits inside the other. On these Delphi connectors the female connector shell fits inside the male connector shell ![]() The 2nd picture in my post above, shows - Female terminals fit into Part A Male terminals fit into Part C The 1st picture shows the component parts of both male and female connectors. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Hi
this is just an update the the previous posts, along with some pictures of how i have over come the issues i found when installing the cruise control first off, i did not like the idea of cutting onto the wiring loom. this is a destructive way of doing thinhgs, and when you encounter problems as i did, you then have to take it all out, and try to re-solder the wires. to over comew this, i have made an extenstion to the T-Harness supplied. i sourced the connectors as uised by land rover - thank you PaulMC - and the same coulour coded wire from Vehicle Wiring Products and made the this:-= ![]() Click image to enlarge this is th efinished prototype. i say this, as there are some things i have done, which can be improved upon. the harnes connectors are to close, and do not allow easy fiiting close to the throtle pedal, if these where longer, a neater job belo could be done, and even allow for the mounting of the cruise control units in a better location, say undeer the seats. this is a close up of the the connector that fits onto the existing plug ![]() Click image to enlarge and this the connector that goes to the throtle pedal ![]() Click image to enlarge the results are fairly good, in that the cruise unit becomes almost plug and play, and can be removed in a few minutes should the need arise. i will post more on nthis, once i have devisd where the unit is to be mounted and where the wires will run. whatch this space. Cheers keith puer claudius |
